02-23-2013, 04:52 PM | #1 |
are c10 and k10 cab mounts the same?
just out of curiousity here, are c10s and k10s and k20/c20s all the same cab mounts? and what years all bolt up if so. the threads ive found are people converting their frames to accept a pumpkin. id imagine they are. just curious in the case that i found a k10 swb frame....
-Mike- '94 GMT 400 ext z71 3" body, 3 in rough country, hd mirrors, 20" motometals on 35s |
02-23-2013, 06:06 PM | #2 |
Re: are c10 and k10 cab mounts the same?
From memory, the C10 is unique.
All 4 mounting pucks under the cab are the same. Id estimate they are 1" to 1 1/4" tall. All K-trucks and C20 & up have a shorter frame bracket (compared to the top of framerail height) than the C10. Therefore the rear pucks are approximately 3" tall. There is also a difference in the core support mounts. 67-8 are different then 69-up. Shane |
02-23-2013, 06:59 PM | #3 |
Yep,the C/10s are all by themselves and shorter. Core support mounts vary from 67/68 to 69-72,but don't vary between 10-30 series
02-23-2013, 11:45 PM | #4 |
Ok so i guess i couldnt swap a c10 cab over to a k10 frame
02-24-2013, 07:06 AM | #5 |
Yes,but it's best to use one from a 4spd or big block w/high hump floor. since that's required on a K-model. You can graft the area from the old cab or cut it from a junker. That area is always in good condition.
02-24-2013, 02:11 AM | #6 |
Yes you can swap the cab from a c10 to a k10. The difference is that you would need to get the cab mount bushings for a 4wd versus the cab mount bushings for a 2wd. Hope this helps you.
LIFTED OR LOW THE ONLY WAY TO GO!!!! Check out my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=517346 Projects 56 Chevy pickup Porterbuilt FR/RR dropmembers |
02-24-2013, 04:24 AM | #7 | |
Shane |
02-25-2013, 12:07 AM | #8 |
oh cool. well if i come across a good frame i may snatch it up and go back to the country boy that i am with a 4x4
09-04-2020, 01:07 PM | #9 |
Highjacking this thread slightly.
Would it be possible to put a C20 body onto a K20 frame? A 1970 body onto a 70-72 K20 frame. Just a curiosity I have.
-JASON My grandpa, Gramps, won a 1970 C20 in 1969 for $1. I'm on a mission to restore it before he passes. My 1970 C20 Build Thread |
09-04-2020, 10:41 PM | #10 |
Yep. Cabs is cabs. They all mount the same. 4wds have a high transmission hump that is removeable. So do big block 2wds and 4spd 2wds. Those can be fitted to a low hump floor. The outline is stamped into the floor
09-05-2020, 02:28 AM | #11 |
Thanks Special K for the response. I both trust and value your knowledge.
Follow up questions, if I may: 1. Assuming beds can be swapped too? 2. Would the C20 cab on a K20 frame/drivetrain produce any other issues outside the hump (which I was aware of)? For example, steering column, etc.
09-05-2020, 03:05 AM | #12 |
From what I have seen the K series has a different lower core support mount. More like a puck (like the upper) than the cone that the C series uses. The cone style still fits though.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
09-05-2020, 05:02 PM | #13 |
Hypothetically could one remove the cab and bed from a K20 and replace with a C20 cab and bed?
Im assuming the K20 front clip would align properly to newly place C20 cab. And for anyone who reads this, I'm asking because I'm considering buying a K20, but putting my C20 cab/bed on.
09-05-2020, 05:25 PM | #14 |
The only sheet metal difference is high hump low hump in the cab gm even gives you the nice line to cut out a lot hump for installing high hump pan
Many people have went this route i did it to my 68 c10 to k10 like 30 years ago there is a guy in the build threads look up his c10 to k20 thread The cab rubber mounts are different from c10 to c20 c20 are the same cab mounts as the k trucks 67 68 trucks had a different rad support mount then the newer frames which you can cut down to fit |
09-06-2020, 01:49 PM | #15 |
So could I in confidence do all the body work on my C20 before finding a K20 donor chassis without concerns of having to rip into sheet metal again later in the process?
Please forgive that run-on sentence.
