62 c/10 windshield /back glass
Any tips on getting the glass out in one piece. Never removed a windshield with the rubber around it. Also anybody have a line on new windshields for the 62. This one is use able,but rubber is rotten so has to come out anyway. Has a couple chips in it and bubbles around the edges. Just don't want to break it in case I do use it again.
![]() Join Date: May 2007
Re: 62 c/10 windshield /back glass
use a knife and cut out the rubber around the windshield, sometimes local glass shops carry windshield and some will replace it.
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
#3 | |
1961 crewcab
rear window is much easier, pick a good hot day, so the rubber is a little more pliable, pull the bead lock out, and then at the seam slowly start working the rubber over the lip.
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
