Brake line touching exh. pipe question
I know my brake line at one point it touchs a header pipe. I know it should'nt but does anyone know what can happen? I would think the fluid would expand a little is all. Or does it get foamy?
69 C10 longbed: 357c.i. /TH400/3.73s/AC/ beige primer/saving $ for paint ______________________________ |
Livin' it up.
![]() Join Date: Nov 2001
could prolly boil it or cause the expansion to get nasty and maybe trip the brakes... dunno for sure
-Greg; Sold the 69 C20. It's off to a better home with more love! Now onto the 86 CUCV M1009; K5 blazer with 6.2L diesel, corp 10 bolt axles, Detroit locker in the rear, trutrac front, 3.73 gears, 35" tires. ![]() |
Most brake fluids can survive high temperatures, (over 200 degrees F), but I would be very concerned about the very real probability of the contact abrading/corroding the line and causing a leak. I would suggest getting the line to clear.
Jim |
Getting cabin fever?!?!?!
not to mention the possibility of the brake line getting crushed by a good bump from the exhaust. my exhaust swings back and forth on my ford enough to have dented 3 inch tubing.
Member of the Discs Up Front Club 1972 GMC 1500 1994 F-150 XL 4x4 Tact is for people not whitty enough to be sarcastic |
On the left side I bend the lines back about 2" and tuck them back behind the crossmember.
A great suggestion from Mark25 is to use heat shielding around these brakelines to keep the heat off them, also providing a little protection from rubbing. http://store.summitracing.com/partdetail.asp?part=3012 |
