05-09-2012, 08:09 AM | #1 |
Bed removal
Does anyone have pictures of removing bed? I need to know how because I got 2" drop shakels and I must lift the bed to get the bolt and nut out
05-09-2012, 09:21 AM | #2 |
Re: Bed removal
Yep - just cut the 8 box bolts loose and undo the license plate lamp connection.
You'll also need to undo the fuel filler neck and a ground wire on that side, if you are going all the way off. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
05-09-2012, 09:22 AM | #3 |
Re: Bed removal
Loosen the bolts that go through the bed floor and lift. If you lift it to far make sure you unplug your tail lights, there also should be a vent tube from the rearend that is attached to the bed floor. Also loosen your gas filler tube if you still have the factory gas filler.
05-09-2012, 09:27 AM | #4 |
Re: Bed removal
Dont forget any ground straps you might have..
05-09-2012, 09:29 AM | #5 | |
Re: Bed removal
John 82 Chevy Silverado 350ci/TH350 |
05-09-2012, 09:48 AM | #6 |
Getting Old; Going Broke
Re: Bed removal
I've never had to take the bed off to remove the shackles. You will have to notch a bed brace if you're putting on lowering shackles though, but that can be done with the bed on the truck.
Why is every used 350 sbc out of a corvette? There's only two things that excite a man, expensive toys and real expensive toys. VEGETARIAN: That's an old Indian word meaning "I don't hunt so good." When the going gets tough, switch to power tools. |
05-09-2012, 09:31 PM | #7 |
Re: Bed removal
Thanks guys I've been working on it for like 3 hours the stupid previous owner putted the bolts the other way round they were hitting the bed and I had to lift the bed for a foot just to get the bolts out I finished everything and now the bed sits on leafsprings its ok tomorrow I will cut the brace and another thing I found out that all 8 bolts were loose !!
05-10-2012, 09:42 AM | #8 |
Re: Bed removal
Pictures are not that clear
Before After The shakels are 2" drop and I didnt notched the bed brace and now the bed sits on the leaf springs but do you think it will get low litte bit more after notching? Posted via Mobile Device
