10-27-2022, 11:44 AM | #1 |
Special tools
As I am getting older, weaker, and hopefully wiser, I find myself looking for tips, tricks, and tools to make the job easier. The purpose of this thread is for a log of innovative, homemade or store-bought tools to save my back. To start I am looking for an easy way to put wheels on my truck. I struggle to lift a wheel/tire combo up 2" while lining up the lugs. I've used levers, pipes etc to get by. But, I think someone out there is smarter than me and has an easy way. Please post up anything you have for this problem as well as other helpful tools. If this is duplicating a prior thread please post a link. Thanks.
10-27-2022, 12:02 PM | #2 |
Re: Special tools
I use to work for Goodyear for over 22yrs I feel your pain. Heavy ones I did on the ground I used a long pry bar to lift the tire/wheel up so I could start it on the lugs. Another easier way if you can get the vehicle high enough is to use a motorcycle jack. That works real well. I use it here at my PC shop to raise heavy 4x4 wheels/tires up to get them on the balancer.
Harley 1969 Chevy C-10 Long Bed, 350cid, 700R4 |
10-27-2022, 12:05 PM | #3 |
Re: Special tools
Well for me I use what you already have, my legs. I just sit and put tire across my upper legs and just lift tire up to wheel studs and rotate if needed to get over studs. I first set the tire with the holes close to orientation they need to be so minimal roll left or right to line up with studs. Basically, let legs do the lifting, not back or arms
While I have not seen one, you could make a curved cradle that goes on a floor jack to support tire but obviously you still need to lift the tire onto that cradle, balance guide it with one hand while you jockey floor jack into place |
10-27-2022, 05:42 PM | #4 | |
Beep! Beep!
Re: Special tools
1972 Chevrolet C/10 shortbed, stepside, 350, HEI, Fire Engine Red, Black Interior, Former Army cargo transport 2003 Chevrolet 2500HD CC 6.0 4wd 2004 Jeep Rubicon some aftermarket stuff... 2019 Jeep Unlimited Rubicon (the wife's baby hauler) |
10-27-2022, 06:57 PM | #5 |
Re: Special tools
10-27-2022, 07:17 PM | #6 |
Re: Special tools
Motorcycle jack . I’ve used it to install tires on my dodge 315/70-17 34.5 inches tall and it works well as a transmission jack .
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. |
10-27-2022, 07:33 PM | #7 | |
20' Daredevil (Ret)
Re: Special tools
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
10-27-2022, 07:46 PM | #8 |
Who Changed This?
Re: Special tools
Sore back, indeed. I pulled the PG trans out of my '65 Malibu and put in a 350 trans, with no jack. Just John Armstrong. The older I get, the better I was. I wouldn't even try to pick that trans up off the ground, let alone bench press it into place, these days. It's probably why my body is so trashed...
10-27-2022, 12:41 PM | #9 |
Re: Special tools
I had a set of car Dollie’s like in this link. I modded one to fit a small bottle jack on one end in the middle and could lift one side enough to lever the tire high enough.
They do make ones now that have a hydraulic ram attached. A bit pricey though. https://www.summitracing.com/parts/mrm-m998035 |
10-27-2022, 04:59 PM | #10 |
Who Changed This?
Re: Special tools
Make a rectangular frame out of 2" X 2" lumber, 4 feet long and 1 foot wide. Put it together with screws. You should be able to roll the tires onto the wood. The end you're going to lift should be attached above the long pieces so that you have a handle. You should have plenty of leverage that way. I knew a guy who weighed all of 140 soaking wet who worked on big trucks. He used something similar, but greased the wood. I personally don't want grease on my tire treads, so I just use that assembly as a pry bar. I have the arm strength, but an arthritic back is my problem.
10-29-2022, 02:16 PM | #11 |
BlahBlahBlah
Re: Special tools
10-29-2022, 05:21 PM | #12 |
Who Changed This?
Re: Special tools
I used to do that with 4-cylinder engines in Chevy Vegas. Just the short block. Pick it up, sit on a fender and swing over, plop the engine into place. SBC short blocks off the ground, into the bed of a truck, alone. Yup, I'm paying for it.
10-31-2022, 10:03 AM | #13 |
Re: Special tools
With a new house and commitments, you were in a tight spot in more ways than one. Necessity is the mother of invention.
10-31-2022, 11:11 AM | #14 | |
Re: Special tools
The best tool for a bad back is a lift.
Yeah, that was my song. Freezing pipes added their own special flair. Or was that flare? Of all things, that was a record breaking winter for cold and snow also. I don't think I was barefoot, she wasn't pregnant, and my dog was just a healthy puppy
10-31-2022, 10:25 AM | #15 | |
Re: Special tools
10-31-2022, 11:04 AM | #16 |
Re: Special tools
Have any leaf springs laying around? I have a leaf out of a set that is about 18" long and has a nice curve on it. Slide one end of it under the first rib or two of the tire tread and push down on the other end.
Easy Peasy. They even have a hole in them to hang on the wall and is ready to use as a pry bar for anything else. I have two different lengths hanging on the wall that have been used for hundreds of different things.
'67 GMC 2500, 292, 4spd, AC |
10-31-2022, 01:27 PM | #17 | |
Re: Special tools
1. Distributor wrench says snap-on and came from a used tool store that no longer exists. The used price was $15. The online catalog price for new was $48.50 in 2008. Now I see it online for $81.25. 2. Brake bleeder wrench. 3. GM door handle/window crank spring clip remover. Link to original post: https://67-72chevytrucks.com/vboard/...d.php?t=272608
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
10-31-2022, 02:20 PM | #18 | |
Who Changed This?
Re: Special tools
10-31-2022, 05:03 PM | #19 |
Re: Special tools
Over the counter tools are nice, but the OP was looking for home made tools as well.
I still use the old style beam torque wrench's, but mine is limited to 100 lb/ft. A length of channel iron that effectively increases the "lever length" can increase the range of the torque wrench. In my case, I doubled the "lever length" and doubled the range to 200 lb/ft. It was easy to bolt a breaker bar to the channel iron and cut a square hole for the torque wrench. I just have to remember not to use that piece of channel iron for some other purpose.
10-31-2022, 05:17 PM | #20 |
Re: Special tools
I do have one store bought tool that I never use, but when I do, its worth ten times what I paid for it. The short arm on the left has fittings to latch into most door latches, but if you remove that arm you can roll the door in to be completely flush with the body.
One-man door installer with no fuss. HF hasn't sold it in years. Much of what they sell is junk, but this thing is golden.
12-22-2022, 01:07 AM | #21 |
Re: Special tools
For handling wheels I use a long handled shovel. Lots of leverage with the handle, enough clearance to push down and a little shove and the wheel is on. |
12-22-2022, 03:45 PM | #22 |
Re: Special tools
I have many "use once but worth every penny" tools. A valve spring, Crane, that was $100 20 years ago and now extinct but worth every penny. I have used it several times for swapping springs with heads on engine and engine installed.
Few homemade ones to...like this spark plug socket mod for getting plug in/out of that one cyl the header makes difficult. It slides on plug sideways and a open wrench to turn the cut down head to loosen, then just remove plug by hand |
12-23-2022, 12:34 AM | #23 |
Re: Special tools
I needed a holding tool for the balancer on my daughter's Subaru. I was going to weld one up (they list for over $50 on Amazon, and who's got time to wait...) but then I got smart. I grabbed a piece of 1" square tube off my metal pile and drilled two 3/8" holes in it and ran 2" bolts through the holes. It worked like a charm. I threw it aside in case I ever need it again.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
12-23-2022, 10:10 PM | #24 |
Re: Special tools
LS engine tools. Balancer removal and install tool. Valve spring removal tool. Timing cover alignment tool. Oil pump alignment tool. Push rod length checker.
03-05-2023, 11:03 AM | #25 |
Re: Special tools
Following up, I saw this on TV this morning. Sema new tool award winner. But, a little expensive for me.
https://www.liftwithtrac.com/pages/t...mance-features https://www.liftwithtrac.com/products/trac-tire-jack |
