09-22-2004, 02:27 AM | #1 |
Aftermarket cruise, $40 plus shipping
I have an aftermarket cruise setup that I pulled from a 71 pickup. The 5 wires between the interior pieces (switch and relay) and the speed box are cut, but they are color coded and just need to be spliced. It has 3 additional wires, I assume 1 for ground, 1 for power, not sure what the 3rd is for. It needs a vaccum supply, and then a vacuum line run to the throttle control. It has a short speedo cable that goes to your speedo. The cable that used to go to your speedo hooks up to the speed box, which will control the amount of vacuum that goes to the throttle control.
I do not know if this works, I pulled it out of a non-running truck. I think it's al there, except for the vacuum lines, they were pretty crusty. It was made by Dana. I can email you pictures. Shawn
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
09-22-2004, 02:45 AM | #2 |
Fixing my 67, & loving it
Send pics to inspector722@aol.com
Email address- inspector722@aol.com Zip Code- 77611 Shipping- DHL & USPS Working on: 67, large back glass, 307 V8, 200 4R, 3.73 rearend, Short Stepside Bed |
09-22-2004, 03:07 AM | #3 |
Pictures
09-22-2004, 03:13 AM | #4 |
ill take the cruise switch if no one wants the rest of it and the shorter speedo cable
09-22-2004, 03:16 AM | #5 |
But it all, sell what you don't want
I will give it 2 days, if no one wants it all I may seperate. |
09-22-2004, 03:17 AM | #6 |
lol i c well i just bought a full one in good shape but im not sure if it has a switch and a good short speedo cable so thats y lol let me know if u do decide to
thanx Nick |
09-22-2004, 03:36 AM | #7 |
Email sent.
09-22-2004, 08:05 PM | #8 |
"Ochre Ogre"
to help someone out, I am 99% sure I have the installation manual for this set up. I can make copies or scans if you need them.
Bowtie Truck Stop Inc. Mid-West GM Truck Restoration Parts Supplier Your Key Parts, Auto Metal Direct, Dynacorn, and Goodmark dealer. like us @ www.facebook.com/BowtieTruckStop 1971 C-10 Suburban (Ochre) 1971 K-10 Suburban (Ochre) 1972 C-10 Suburban (Ochre) 1972 K-20 Suburban (Yellow- that just aint right!) Springfield, Minnesota 56087 |
09-23-2004, 12:46 AM | #9 |
im pretty interested in this...how does it mount to the intake or whatever to control the carb? how chinsy does it look?
67 c-10, 400 SB, TH350, 4.10 gears, Blazer tank,camaro tach, sidemarker fuel fill (soon) WTB: stepside parts, 67 front end parts, 67 small window cab. posi for 3.73 or 4.10 for 12 bolt and 10 bolt. |
09-23-2004, 01:23 AM | #10 |
The round part mounts to the firewall behind the engine (usually) and it has a chain/linkage that goes from it to the carb. The round thing is actually like a bag, and when it wants to accelerate the speed control box pulls the throttle by sucking in the bag with vacuum, which pulls on the chain/linkage.
The speed control box was mounted to the driver's side inner fender.
09-28-2004, 11:05 AM | #11 |
PM sent.
