Old 10-29-2012, 07:11 PM   #1
Squareforceone
Squareforceone's Avatar
Angry Need help with rear brakes please.
I'm a my wits end with my truck right now.. I spend the last few days replacing the rear brake shoes and wheel cylinders. So, i finished up on Saturday night and thought all i had to do was bleed them last night. So i go and put on the passenger side drum its a PITA at first but eventually get it on and can spin it. So i go the drivers side and that drum wont go on at all everything's hooked up the correctly and the star wheel on both sides is adjust so the shoes are all the way in. So i went out and bought a hardware kit thinking a spring was worn out. I get that all done and the drum goes on ok. but but then wont budge at all just stuck solid i also noticed the actuator leveler isn't coming down all the way the star wheel spins freely in both directions. I don't get it i replaced everything on the drivers side but the actuator leveler and actuator spring.
Rust is better than rice.
Squareforceone is offline   Reply With Quote
Old 10-29-2012, 10:34 PM   #2
slugish
Slugish
Re: Need help with rear brakes please.
Sounds like your emergency brake cable is not releasing as it should . Had a similiar problem > disconnected the e brake cable on the side that had frozen .
Good luck
slugish is offline   Reply With Quote
Old 10-29-2012, 11:09 PM   #3
bilfman
bilfman's Avatar
Could be the cam on the e brake side of things.
1979 Chevy Dually Crew 4X4 454, D60 Tru-trac, D70 Detroit Locker, 3.73, 4L80E/NP205
1971 GMC 3/4 Ton 4X4
bilfman is offline   Reply With Quote
Old 10-30-2012, 03:10 PM   #4
Desert1957
Desert1957's Avatar
Good luck
Yes, this gets my vote also. Here is a "Generic" parts list of a common drum brake setup , Our trucks are a little different but you get the idea. If the E-brake is not released all the way , shoes will not seat on the top anchor pin.
Desert
Desert1957 is offline   Reply With Quote
