11-16-2009, 04:02 PM | #1 |
SWB 4x4 Collector
how to test a tach???
Hey guys, I am trying to figure out how to test out a tachometer to see if it works. What is a way to test it without it being in a vehicle? I remember there is ways to do it with power to it, but I don't remember the process. Thanks guys, Trevor
TREVOR 1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks) 1972 Jimmy (soon to be Hickey cloned) 1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track) 1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank 1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT) http://67-72chevytrucks.com/vboard/s...d.php?t=624819 1989 V3500 Crew Cab (454tbi, NV4500, np205) 1970 Chevelle SS (LS5 454,th400,8track,buckets,tach) :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever |
11-16-2009, 04:03 PM | #2 |
Tot Roddin'
Re: how to test a tach???
Signed in for this one too...
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
11-16-2009, 04:38 PM | #3 |
The Older Generation
I don't know why you couldn't lay the cluster or tach on the cab floor or seat, run a jumper wire to the "unfused ignition" terminal on the fuse panel, one to the HEI "Tach" connector on the distributor, one to ground, and start the truck up. LockDoc
11-16-2009, 04:42 PM | #4 |
SWB 4x4 Collector
Leon, well this is a camaro tach dash conversion I want to test and then sell. I just want to make sure that the tach works before I sale. My truck is out of commission right now, but we have a gm truck that we could hook up to the dizzy. Thanks Jim for your help as well. Trevor
11-16-2009, 04:37 PM | #5 |
The way I test a tach is to hook power to the tach, (ground the case, positive to the + post on the tach). I then run a wire to the "Tach" connection of an HEI distributor or to the - side of a coil if points are used.
If a tach is good it will register the rpm. If it is out of calibration I use my Snap-On Tachometer as a reference to adjust the tach to. Both tachs can be hooked up at the same time. I have also used my distributor machine to test tachs on and it is a similar procedure but instead of a battery, I use a 12 volt DC battery charger. Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC Last edited by JimKshortstep4x4; 11-16-2009 at 04:41 PM. |
