Old 11-05-2002, 07:40 PM   #1
67cst
i love summertime
67cst's Avatar
front clip removal...help
i plan on removing the front clip of the 67 this weekend, what all needs to be done? where are all the bolts located? thanks
Derek
1967 shortbox stepside Chevy, 365 hp 327, th400.
GLOVE BOX LIGHTS FORSALE, click link for info
http://67-72chevytrucks.com/vboard/s...d.php?t=273724
67cst is offline   Reply With Quote
Old 11-05-2002, 08:18 PM   #2
Mudder
Mudder's Avatar
Lets see!
two bolts rear of fender top and bottom. One inside of the fender well. two in the front. the front wiring harness will unbolt from the fuss block. u may have to take the cowl off, cant remember (CRS).
Mudder is offline   Reply With Quote
Old 11-05-2002, 08:23 PM   #3
67cst
i love summertime
67cst's Avatar
thanks mudder
ill have some progress pics this weekend, cant wait to show ya guys a whole lot of nothin, hehe
Old 11-05-2002, 11:10 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Don't forget to remove (possably) the battery cables, the washe bottle hoses, the bolts under the radiater...and the rad hoses and tranny lines (if equipped).
Old 11-06-2002, 02:44 AM   #5
67cst
i love summertime
67cst's Avatar
longhornmail
thanks for the tips, keep em comin
Old 11-06-2002, 08:35 AM   #6
okietruck
You will have to pull the cowl to get to the top fender bolts. The hardest part for me is getting the wipers off. I'm starting this as well this evening on my 72. Need to replace the heater core and pulling the clip is easier than dropping the inner fender. I'm kind of upset about having to do this again, I installed a new core in January when I put the crate motor in.
okietruck is offline   Reply With Quote
Old 11-06-2002, 10:05 AM   #7
dubie
dubie's Avatar
If you plan on taking the inner fenders off with it, there is 1 big bolt near the back on the inner side. If you are leaving them on, there are screws to remove on the outside where the innner and outer meet up. The cowl should be removed before doing this job, and the wipers just pop off with 2 screwdrivers.
Good luck and keep us posted
My name's Tim and I'm a truckaholic
My 56 Chevy shop truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=562795
dubie is offline   Reply With Quote
Old 11-06-2002, 10:26 AM   #8
Yukon Jack
Yukon Jack's Avatar
"Wipers just pop of with two screwdrivers" Come pop mine off for me then - I fiddled with the wipers for 20 minutes last night and couldn't get them to come off :-(
About the bolt on the lower part of the fender just in front of the doors, the metal around that bolt on both fenders was broken off of the inside of the fender. Is that common?
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 11-06-2002, 10:33 AM   #9
Piston
Piston's Avatar
Lift the wiper arm all the way up, look near the base and you will find a lever attached with a rivet. Slide this lever out, this supports the wiper arm and allows you to just wiggle the arm off the shaft.
The other style wiper arms have a hole drilled through the base, lift the arm, slide a drill bit through the base. This supports the arm and again, just wiggle the arm off the shaft.
Piston is offline   Reply With Quote
Old 11-06-2002, 11:07 AM   #10
Canada20
Man! talk about timing! I'm planning on trying this over the next couple of days too!
When you guys say front clip, does that mean that i can take pretty much the whole front sheetmetal off all at once?
Greg
No such thing as a stupid question, right?
Canada20 is offline   Reply With Quote
Old 11-06-2002, 11:17 AM   #11
Yukon Jack
Yukon Jack's Avatar
Yep. It all comes off as one piece. Pretty darn handy for the amount of work your getting ready to do.
Piston, I messed with the little clip that your talking about and still couldn't get it to work loose. Have to work on it some more tonight.
Old 11-06-2002, 11:32 AM   #12
Piston
Piston's Avatar
the pot metal and steel they used causes corrosion that makes them tough to move at first.. PB blaster works great for that. It will climb up into the arm assembly and usually makes it so the arms slide right off. If that doesnt work, I've had to make a fork to attach to my slide hammer and "persuade" them off that way LOL.
Old 03-22-2006, 07:31 PM   #13
Chevrolet4x4s
Chevrolet4x4s's Avatar
Re: Why guns must be outlawed and confiscated
I think I beat the system...pssting in a closed thread hopefully I won't get :b1: is posting in a closed thread against the :rulz:
Shane
Edit: 1 more try
1993 K1500 350 5 speed
1985 K10 Silverado Vortec 406 5 speed (in body shop)
"I been drivin' this '85 pickup truck Them buddies of mine call it a bucket of rust She's a little beat up but she still runs like the wind Yeah, kinda like me I been banged and bruisedBeen around the block a time or two But I'm runnin' like new goin' places I never been
No, I ain't broke I'm just broken in"
1963 Dodge Townwagon(its amazng what 30 years and zero miles will do to a vehicle )
Member#20327
Chevrolet4x4s is offline   Reply With Quote
Old 03-22-2006, 07:33 PM   #14
Chevrolet4x4s
Lets play beat the system
Edit: I shall have to devise another way to do it
Att. Mods I am not a hacker... just bored
Member#20327
Old 03-22-2006, 09:49 PM   #15
Longhorn Man
Re: front clip removal...help
How did posting in a locked up thread about guns, end up on a 4 YEAR OLD THREAD???
Old 03-24-2006, 01:20 AM   #16
chevy_fatman
Where's my beer?
chevy_fatman's Avatar
not only he's trying to stir $hit up, but winds up posting in a totally different thread or maybe the mods moved his post to this one to make him look like a 'tard
Paul
How do you make the invisible, visible?.........You take it away.
chevy_fatman is offline   Reply With Quote
Old 03-23-2006, 01:23 PM   #17
shifty
Questionable
shifty's Avatar
wtf?
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 03-23-2006, 01:25 PM   #18
1969k10stepside
I wonder if he ever got the clip off?
1969k10stepside is offline   Reply With Quote
Old 03-24-2006, 09:02 AM   #19
72armyswbtruck
72armyswbtruck's Avatar
I was also going WTF?
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!"
72armyswbtruck is offline   Reply With Quote
Old 05-02-2006, 09:28 PM   #20
Chevrolet4x4s
Just got back on here going through my old posts rotfl I pulled up a reply page and put in the thread number of the other thread but it didnt work so I ended up looking like a tard
Shane
Member#20327
Old 05-02-2006, 10:20 PM   #21
1LoC10
Insert Title Here
1LoC10's Avatar
4 years later........... so how the hell do i get my wipers back on now
BOBBY
_69 SWB_
1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all <<
1LoC10 is offline   Reply With Quote
Old 05-03-2006, 06:13 PM   #22
Chevrolet4x4s
Ya still got the wiper studs there?
Shane
Member#20327
Old 05-03-2006, 08:05 PM   #23
72armyswbtruck
push really really hard
Old 05-04-2006, 12:07 AM   #24
Bob Moore
I feel like a retard on this old thread from 2002. Reading back I saw "Dubie".
Where is Dubie now? Wasn't there a whole family of Dubies? Mr. Mrs. and Jr.?
Project finished? Burned out? or just quiet. He always had something good to say. I miss that.
67 C-20 LWB, tilt, speed alert,
vac, 454, T400
67 C-10 SWB, factory air with
more to follow
Bob Moore is offline   Reply With Quote
Old 05-06-2006, 06:48 PM   #25
Chevrolet4x4s
Dubie's Last Activity: 01-19-2006 03:01 PM
Member#20327
