Old 06-19-2016, 11:58 AM   #1
42_NATO
Sm420 what should i do with it?
So finally got the clutch in and now i look at this nasty transmission and wonder why it's covered in so much crime and wonder what I can do should I just clean it up or should I replace gaskets.what do u guys think?
42_NATO is offline   Reply With Quote
Old 06-19-2016, 01:07 PM   #2
61K10
61K10's Avatar
Re: Sm420 what should i do with it?
Clean it before any gasket replacement. It's just manual labor lol! My 420 had some under coating sprayed on it and it was tough to remove.
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 06-19-2016, 01:15 PM   #3
Softpatch
Softpatch's Avatar
Boat anchor !...oh wait were you from tolleson.? like Texas.?
How about counterbalance for barn door.?
My Spelling is Not Incorrect...It's 'Creative'
1966 C-20 .....Swap 91 G-30(5.7 FI)/4L80E
http://67-72chevytrucks.com/vboard/s...d.php?t=789617
59 Viking Revival .. http://67-72chevytrucks.com/vboard/s...d.php?t=632341
Softpatch is offline   Reply With Quote
Old 06-19-2016, 01:55 PM   #4
42_NATO
Tolleson arizona
Old 06-19-2016, 01:49 PM   #5
42_NATO
pics
Old 06-19-2016, 01:51 PM   #6
42_NATO
There was alot of grime slash foam. Not sure it gear oil or some obe sprayed it with somthing
Old 06-19-2016, 02:55 PM   #7
Chknlyps2
Was the bell housing just as dirty? Could be years and years of engine leaks being blown back from the fan and road wind. I have seen many auto trannys caked with grime like that on top and above the torque converter and there is no place they can leak there.
Chknlyps2 is offline   Reply With Quote
Old 06-19-2016, 03:02 PM   #8
42_NATO
Yes the bell housing was the same . the engine leaks from the front seal. But not enough this seems to be old caked on stuff. I thought it may have been from the tranny. I will started the cleaning soon
Old 06-19-2016, 04:38 PM   #9
urmyboyblue
Use some Easy Off on it, let it set for a few and wash it off with a pressure washer. Don't get Easy Off on the rubber boot! Works like a champ.
urmyboyblue is offline   Reply With Quote
Old 06-19-2016, 04:30 PM   #10
sags
I took mine out and had the same differently- colored grime. The new one I picked up had a foam ring that sits on top under the transmission hump in the cab. I think after 50 years, that ring just melted. Cleaned mine up with a wire brush and lots of scraping. Came out like new. Let me know if you want pics.
sags is offline   Reply With Quote
Old 06-19-2016, 06:51 PM   #11
66Gilbert
1966 Crew Cab & 4X4 Fanatic
66Gilbert's Avatar
What sags just mentioned. A lot of that is the foam heat and noise control seal that has melted after 50 years of heat and absorbing some oil. Every SM 420 I have removed looked just like the one pictured above.
66Gilbert is offline   Reply With Quote
Old 06-19-2016, 07:55 PM   #12
42_NATO
Yea thats what it looks like
Old 07-04-2016, 09:57 AM   #13
42_NATO
So i finally got it mostly all back together. And she all up and running. Did find a gear oil leak at the rear were the drive line hooks up to it
Old 07-04-2016, 11:21 AM   #14
oem4me
The foam seal had melted indeed. My Suburban has low miles and no oil leaks, yet that foam seal had turned to tar and was slowly running down the sides of the trans. I too was puzzled at first about the sticky goo on the driveway.
