Old 09-10-2014, 09:38 AM   #1
Custom 68
Custom 68's Avatar
need advice on a top...
http://springfield.craigslist.org/pts/4646544913.html
Ok gang, I am new to this. I have a 72 blazer I am about to start working on. It has a double wall top with a broken front corner, I was going to work on it and fix the top the best I could but I just found this one. It appears to be a single wall. I have not looked at it other than these pics. What do you think? or is it too tough to tell from this info?
Dave
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 09-10-2014, 09:50 AM   #2
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
Re: need advice on a top...
Save your money and get a soft top. I haven't had the hard top on mine in years.
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 09-10-2014, 03:05 PM   #3
pd1219
pd1219's Avatar
If it has lights inside it is a single wall top, I believe. If yours was a double wall top originally you will have to modify the bed side tops to accept the bolts to attach the top. If your bedsides have threaded inserts in the holes on the top of the bedsides you are good to go. Looks like a good start to me, and it has the lift gate still on it. good find! it does look like that lift gate has a crack on the left side near the handle..
pd1219 is offline   Reply With Quote
Old 09-10-2014, 03:19 PM   #4
Custom 68
Custom 68's Avatar
Thanks bouncy I will give that a definite thought. I know these tops are all heavy and not super easy to always remove.
pd1219 Yes mine is a double wall I had seen the modifications and figured I could get the strips and correct bolts to convert. I saw that crack too and there may be others. I may try to look at it when I can just to see. I had posted in a thread a couple down and know more about these tops because of that.
I am not ready for a top yet but thought if the pricing was good I should snatch it as they sure seem hard to find. (all parts for these)
Thanks guys
Dave
Dave
Old 09-11-2014, 04:23 AM   #5
jaros44sr
jaros44sr's Avatar
Thanks guys
Dave
Dave, i have a '72 also, it does have both mounting types, so, check yours as i thought '72s cames that way
Got pics?
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 09-11-2014, 08:24 AM   #6
Bentblazer
Bentblazer's Avatar
Isn't too far from you, better take a look at it, not many of these show up around here.
"85" Monte Carlo SS
"71" K5 (SOLD)
"64" Chevelle
1930 Chevy two door rat
Bentblazer is offline   Reply With Quote
Old 09-11-2014, 08:59 AM   #7
Custom 68
Custom 68's Avatar
Thanks guys I will check mine out, It has been sitting in the waiting room for a couple 3 years to start, it is rougher than I had originally thought. I am about to start the disassembly so I will be able to see it then.
Yep Bent it is not too far from me so I will get him next week and run down there.
Again thanks
David
Dave
Old 09-11-2014, 02:51 PM   #8
Chulisohombre
Chulisohombre's Avatar
As far as I know all 72 came with noth mount holes. I have both on mine also.
72 3/4 ton blazer. 5 inch lift on 35 inch tires. 355 corvette engine with crane roller rockers, rv cam, edelbrock carb and intake with one inch spacer. Thrush Headers with flowmaster 40 duels. 4speed sm465 manual. 4 wheel disk brakes with Inboarded rear shock prerunner style mounts and shocks.
Chulisohombre is offline   Reply With Quote
Old 09-11-2014, 03:11 PM   #9
Custom 68
Custom 68's Avatar
that's great news, does it just take the different bolts? I assume there is a strip on the inside of the top where it bolts for support?
Dave
Old 09-11-2014, 07:18 PM   #10
grillzy
my 72 has both factory installed single wall and double wall options in the bed sides.
grillzy is offline   Reply With Quote
Old 09-11-2014, 07:34 PM   #11
71swb4x4
71swb4x4's Avatar
I would pick it up, $500 is a good price if it's in decent shape. The best thing about single walls is that you can have interior side panels and not have to remove them to take the top off, the bolts are accessible from the top.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
