04-06-2005, 03:28 AM | #1 |
Another Sway Bar Question
I was strolling through the wrecking yard and came across a 68 chevy with the factory sway bar on it. I had the rivits cut off the brackets and took everything home. Here is my question. The 4 bushings are marked as the stock diameter 1 1/16" but they seem to have a small gap once installed on the bar. They seem to be in pretty good shape, but I will replace them anyway. Do the bushings have to be completely tight around the sway bar or are they supposed to have a gap to allow the bar to pivot slightly? Thanks!!
04-06-2005, 04:35 AM | #2 |
Tight. Being loose just allows that much more body roll before the sway bar starts doing its job.
'68 Short Step LS1/T56, Hydratech, Fatman Fabrications Stage III, Baer, Hot Rods to Hell, US Body, S&W, etc |
04-06-2005, 08:28 AM | #3 |
Mike
Your new ones should be tight.It is hard to tell how old the used ones are.The rubber wears and shrinks with age.
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires |
