02-06-2016, 12:06 AM | #1 |
Original A.C or Vintage Air
Hi everyone looking for a little advice/help. I'm trying to get started again and finish this 71 shortbed. Been feelin kinda bad for a couple years I think I have that straightened out now.
It was a AC truck to start. The controls are about all that is left. They do work. The firewall is clean, controls and outlet eyeballs are about all that is left. I know we have hundreds of folks on here with many, many rebuilds. In your opinion would it be better to find original parts piece by piece or go with Vintage Air. Price wise I'm not sure if there would be that much difference. Appreciate all advice. Dan |
02-06-2016, 12:28 AM | #2 |
Moderator
Re: Original A.C or Vintage Air
Since you are starting from scratch, I vote vintage air.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
02-06-2016, 01:04 AM | #3 |
The 72 C10 I`m working on was restored several years ago. I myself purchased it after it sat for a few years. It is a Cheyenne and was a loaded truck. It`s a factory Ac truck. The former owner cleaned up the firewall and it now has a Vintage air system. I agree, if starting from scratch why not do a Vintage AC setup. Just my $$ .02. Dale
02-06-2016, 02:27 AM | #4 |
Cost will be about the same. So the question is do you care either way? If you don't care about having the factory look then go with aftermarket. But if would prefer factory, then its not that hard to get everything you need.
02-06-2016, 10:24 AM | #5 |
Old member
Factory AC/Heater box with 134-A Freon is the way to go. Look's right and is easy to do if you have the parts. I wouldn't change it out if I had all the factory stuff that for sure.
My opinion is the under hood pictures you see of these trucks and they shaved the fire wall's and added the aftermarket AC system makes them look funny like something is missing and it is!
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
02-06-2016, 10:41 AM | #6 |
Vintage Air....
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
02-06-2016, 11:16 AM | #7 |
So Vintage Air works just as well as factory for everyday driving?
02-06-2016, 12:02 PM | #8 |
I think it does depends on the build of the truck. If most everything else is original I would keep the a/c system original. If its customized go with vintage air. With that said my truck is customized and I just finished installing a vintage air system. If you decide to go with the original system message me as I have most of the parts you may need.
02-06-2016, 01:13 PM | #9 | |
Unless your bringing fresh air from outside into the cab (none of the aftermarket units offer this) I would say there not ideal for daily use. Thats from my experience specifically with the OLD AIR system personally I dont like it.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
02-06-2016, 02:49 PM | #10 |
That is an advantage of the factory system. It has a fresh air mode. The aftermarket kits like vintage don't have that.
02-06-2016, 03:52 PM | #11 |
Keep it original brother....as original as you can.
That's what I'm doing with my truck and if I was buying one, I'd pay more for one kept original. |
02-06-2016, 08:25 PM | #12 |
Vintage air & heat
02-06-2016, 01:18 PM | #13 |
If you have most of the old system, make the old system work. It has the fresh air, cowl door, bi-level operation stuff that I don't think Vintage has.
If you're piecing together a factory system and don't have it, it can likely get pricey without a full donor system. Then I'd go aftermarket. Unless this is for a stock restoration, then you have no choice, but hard to do a stock restoration on an AC truck without all the AC stuff!
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
02-06-2016, 02:07 PM | #14 |
Laid Back
Vintage air
72 chevy swb Direct dealers for.. Vintage Air, Porterbuilt, Billet Specialties,Budnik wheels ,eddie motorsports, raceline wheels, intro wheels, Dakota Digital, precision, unisteer, Trimparts, and many many more... Laid Back Recreations.. Full restoration shop and full paint and body.. Kyle http://67-72chevytrucks.com/vboard/s...d.php?t=574629 |
02-07-2016, 09:32 AM | #15 |
My '72 is an A/C truck with all parts present. I will restore that system.
My '67 is built from scratch out of parts from the ground up. I will install Vintage Air
02-08-2016, 11:30 PM | #16 |
One thing for those who live where it gets cold to consider is how good is the Vintage Air heat? All the focus is on A/C. I have no idea how good that heat works. I know the factory heat is fantastic
02-09-2016, 01:49 PM | #17 | |
I usually finish my plowing with the window rolled down.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
02-09-2016, 02:13 PM | #18 |
Run vintage are and you can clean up the firewall and also run one of these sweet heater control panels haha
Corey Jones Designs CoreyJonesDesigns on instagram Ole Silver- 1967 stepside http://www.hotrod.com/articles/1103c...chevrolet-c10/ http://67-72chevytrucks.com/vboard/s...d.php?t=598758 |
02-09-2016, 03:14 PM | #19 |
I've seen the controller online on Dakota Digital's site, but where did you get the bezel for the controller from? Looks real nice!
1972 Chevrolet C10 LWB |
02-10-2016, 08:59 AM | #20 | |
02-09-2016, 02:54 PM | #21 |
Anyone running a Classic Auto Air ac kit? What about Old Air Products? Or is just about everyone on this forum running VA? If so that's interesting because CAA is the same thing and alot of the chevelle/mustang guys use them.
02-09-2016, 05:09 PM | #22 |
I have Old Air in my 69. Heat and cool work great.
02-09-2016, 04:36 PM | #23 |
I am starting from scratch and have installed Vintage Air.
02-09-2016, 09:43 PM | #24 |
Getting a straight answer from you guys is like pulling teeth! Ok I am asking, in a daily driver, do the aftermarket systems work as well as factory? Meaning, here southeast Texas on a cool winter morning going to work, it's humid so my windshield is fogged up, give it some defrost, fog is gone. Turn defrost off, turn heat to about mid range, down the road a bit it's gets a little warm, turn heat down two notches it gets too cool, back up one notch it's perfect.
Do these systems have that kind of control or do you sacrifice because the firewall looks good? Nothin wrong with that, just askin. I'm spoiled!! Last edited by GoodJobTim; 02-09-2016 at 09:49 PM. |
02-11-2016, 05:10 PM | #25 | |
A/C and defrost is good, not perfect, but beats sweating all summer in this georgia heat. The heat is ok as long as you turn the vent louvers toward the floor, defrost works good summer and winter. Like others have already said, factory is best, but tough to do if you don't have a complete system to start with, also i my thoughts also you had better be a good A/C man.
I don't think we get smarter as we get older. We just run out of Stupid things to do. |
