Old 10-01-2009, 11:29 AM   #1
CB24
how low can you lower these trucks....
How low can you lower your truck & still be able to use it as a truck? I want to lower my truck but I also want to be able to haul things in the bed from time to time. Is it something where you have to pick one or the other or can you have a little of both worlds? I have a 69' 1/2 LWB if that makes any difference.
CB24 is offline   Reply With Quote
Old 10-01-2009, 12:46 PM   #2
WCRiot
Re: how low can you lower these trucks....
Buy some 3in lowering blocks for $60 and that will handle the rear
WCRiot is offline   Reply With Quote
Old 10-01-2009, 01:05 PM   #3
tcb-1
Nothing to see here.....
tcb-1's Avatar
depends if you go static drop or air ride. and it will also depend on the total weight of the load, if you have auxillary springs, if your frame is notched.....
there are many combinations.
Doug
THANK YOU to our American Soldiers & Veterans - POW MIA "You will NEVER be forgotten".
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson
tcb-1 is offline   Reply With Quote
Old 10-01-2009, 01:38 PM   #4
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Check www.earlyclassic.com website. They have pix of customers trucks. Used to be one on there that had a "substantial" load in the bed of it, i.e., it was used like it they wanted to use it, in spite of the lowering. I have a 2.5/4 drop on mine and it hauled what I wanted to .....but it's disassembled for a re-do.
Member Nr. 2770
Old 10-01-2009, 01:41 PM   #5
CB24
Cool I'll check that out. Thanks!
Old 10-01-2009, 01:49 PM   #6
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
bag it,slam it, and drive it
it's sitting on the shocks here and with the new shocks it dropped about another 1/1.5 inches....it will lay header pipes and the X will be about 1.5 inch off the ground
Hottrucks is offline   Reply With Quote
Old 10-01-2009, 02:43 PM   #7
CB24
The only problem with bagging it is it takes up bed space.
Old 10-03-2009, 01:22 PM   #8
DZL1
One day.....
DZL1's Avatar
My wheels are by 8". I'm runnuing 235/70/15 no rubbing. Hope this helps.
DZL1.
DZL1 is offline   Reply With Quote
