08-22-2010, 04:16 PM | #1 |
Grandpa in the rustmobile...
HOW are do you bend prop. vavle to Mc lines?!!?!?!
For the life of me I cant make em, Ive tried 2 now. failure!
How do you guys do it and make it look decent, thanks
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
08-22-2010, 04:52 PM | #2 |
Re: HOW are do you bend prop. vavle to Mc lines?!!?!?!
Some of the specialty suppliers sell them ready made. I don't think the average guy can make them himself.
08-22-2010, 05:34 PM | #3 |
What if you were to try the "unhooked" one the other way? IDK maybe the fitting is different but it looks like it maybe installed backwards.
Good luck! Keith |
08-22-2010, 05:46 PM | #4 |
I have pre-bent sets for $15 pair + ship
atheystruck@comcast.net 67 1/2 ton 4wd custom cab 72 1/2 ton 4wd super cheyenne 71 1/2 BB super cheyenne shortbed |
08-22-2010, 05:59 PM | #5 |
buy them prebent ...
08-22-2010, 06:07 PM | #6 |
lol^
Anyone have luck doing it themselves? Any tips etc?
08-22-2010, 06:13 PM | #7 |
i spent a weekend once trying to bend them// called up and ordered some on monday then after that have always just picked up the phone when needed those lines
08-22-2010, 06:30 PM | #8 |
i mounted my proportioning valve on a bracket on the firewall...about 10 inches from the master cylinder. required two 90 degree bends per line plus double flare. looked much neater to me and was very easy to do.
08-22-2010, 07:36 PM | #9 | |
I'm sure we'll all keep that in mind next time you post one of your whines about being discouraged ... Last edited by Shane; 08-22-2010 at 07:38 PM. |
08-22-2010, 07:48 PM | #10 |
mine came with prebent lines but i have never liked the attachment bracket hanging to the side of the master cylinder. i moved it to make it neater...in my opinion. nothing wrong with prebent lines.
08-22-2010, 07:17 PM | #11 |
That does look very good. I think I will do mine that way.
08-22-2010, 07:31 PM | #12 |
Now yall got me thinking..only problem would be that I already have my lines bent nicely going down to K member..
keep it coming!
08-23-2010, 10:11 AM | #13 |
I bought prebent and they were more of a headache than they were worth. The trick is to bend it the way you need but keep both ends long and unflared. Then slowely cut them back until they are about 3/8" too long, install the fittings and flare away. Make sure to make a test piece with a bend to be able to know how long the straight section needs to be to get the flaring tool and the fitting on. Also make sure to put the fitting on before you flare the end. Took a few tries, partly becuase the mosquitos were pissing me off but at the end of the day i will never buy prebent lines.
08-23-2010, 11:53 AM | #14 |
67-72 parts collector,…
Aren't these two lines plumbed to the opposite/incorrect ports?
08-23-2010, 01:12 PM | #15 |
helps explain why it's plumbed wrong
08-23-2010, 10:59 AM | #16 |
It's all preference. You need to come out at an angle and loop it back down. If you come out straight then you need to go past the valve and then loop it like you have. If you are trying to get fancy and do compouind bends it will take you forever if you actually get it to work.
08-23-2010, 11:36 AM | #17 |
Redefining LowBudget
put a piece of 2" pipe in the vise and go slow with the bends......some time I put a closed end wrench on the coupler but like I said go easy..that being said I was able to buy the correct length at Napa for a couple bucks each..once you get them close put the lines in the Pro Valve loose / snug the lines in then gently bend it onto the hanger then tighten the lines down......
I would hate to be on a road trip with you guys??? Buy Buy Buy Buy buY $$$$$ heres an Idea try try try try try !!!! you'd be screwwed if there wasn't a store down the street that had the parts to get you going again??? well I guess you could always have them mailed to your hotel room while you sit there waiting or call a wrecker to tow you XXX miles home while on Vaca..that all sounds like fun!!! Ok rant over!!....keep in mind guys the people that build these things aren't any smarter than we are..if they can do it so can we!!! |
08-23-2010, 02:37 PM | #18 |
Actually it is plumbed right. Mine is a 3/4 ton.
http://67-72chevytrucks.com/vboard/s...d.php?t=184148 Also agree with HotTrucks. I have used a 1" socket and slowly worked it around that to get a tighter bend. |
08-23-2010, 04:02 PM | #19 |
Spanked once
Another tip is to pack the the tubing tight with sand. That eliminates kinking ,especially with tubing pliers.
The ole 350 budget build. |
08-23-2010, 04:54 PM | #20 |
20' Daredevil (Ret)
Had to go check my K20... it's all OEM, and the plumbing matches yours.
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
08-23-2010, 04:58 PM | #21 |
PROJECT 7DEUCE
Pre bent is the only way to go... And hell at 15 bucks save yourself some aggravations..
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
08-23-2010, 06:01 PM | #22 |
lol, I think you got your lines backwards..i'll go take some pics of mine from a better view
I was going to buy prebent lines up until a few hrs ago, when I called my friend (intol old cars trucks motorcycles, mostly fords lol) And he said he has a double flaring tool, Well, Imma just bend it how I need it (Very short, but store bought lines are all too long) and slip the correct fitting on and flare it...Should be simple, im going out to try to get it done up then tomorow maybe go take it and flare it, may even ride the wheeler up there (about 1 hr ride 1 way thru the mtns ) Thanks alot folks, lots of good knowledge here...hope the mosquitos dont get me too!! jk
08-23-2010, 07:39 PM | #23 |
3/4 ARE plumbed backward from 1/2 ton, so HIS are RIGHT. If you do it that way to a 1/2 ton you will have a mess, but it is correct as shown for 3/4 ton. You can bend your own and yes it is easier to buy, depends on what you have more of time or money. Either way you are going to have to invest something. If you will take the sand advice it will help prevent kinks. Also use grease in the dies on the bender as this will help as well and another trick is to use something the radius of the bend you are trying to make- coke bottle or other hard surface to aid in forming the bend.
67 blue step side- bb 68 gold and white swb cst anniversary 68 custom swb hot rod Ls swap 69 swb cst 6 cylinder/ overdrive 69 black/black cst bb swb 70 orange and white cst Canada built truck swb bb 71 black and white super swb bb 71 red and white super swb 72 green and white super swb 4x4 62 nova wagon 400 series Ls swapped 68 Camaro 327/4 speed- 1 owner, original paint 66 Volkswagen bettle 69 auto stick Volkswagen Beetle |
08-23-2010, 09:39 PM | #24 |
Thanks hottrucks! This looks pretty good for now. In the future I might redo em PERFECT and put em on, along with a new prop. vavle..
Ps, Are the holes supposed to be the same size? (I see some of other peoples and the 2 ports look the same size).... This is where I am at, I will double flare em tomorow and hope it dont leak Heres some pics. I wish I would have thought to go get a grape soda in a glass bottle, I looked around the shop for something sturdy and round, but came up empty handed...it looks ok I guess, imma cut it just after the flare, and reflare it tomorow, looks like imma go on a lil 4wheeler ride to get there too
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 Last edited by oldblue1968chevy; 08-23-2010 at 09:41 PM. |
08-23-2010, 11:50 PM | #25 |
i mounted my prop valve on the frame and used braided lines....looks cool and super easy to service/remove if needed.mounted a.n. fittings right through the frame. the extra one hanging in the pic is for oil pressure guage.
