03-20-2004, 10:03 PM | #1 |
help with numbers
Hi all, I have a question about some numbers on my truck. First is the engine numbers off of the pad up by the passangers side front of the block. The numbers are as followes VO609TBC the first O after the V might be a G its hard to tell. I was wondering if it was the correct engine for my truck and was hopeing to find a partial VIN number on the pad but that is all there was. The second set of numbers come from the firewall and look to be wrote on in some kind of marker or crayon. and they are as follows.
47 CE10CST LS7 M38 J70P 47 Anyone know what these mean if anything at all? Thanks |
03-20-2004, 10:14 PM | #2 |
Check out this link for the engine codes on the block:http://www.nastyz28.com/spmenu.html
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction. |
