Old 02-15-2005, 08:59 PM   #1
Z28Owner
Z28Owner's Avatar
Airbag question.....
Can you run rear airbags like you run air shocks? Like where u run 2 bags , then two lines to a T connection then one to a fill valve? Also do u need a guage to see how much pressure is in the bags? I was considering drop spidles and springs in front and rear bags. Thanks for info.
1971 LWB Chevy C-10
350/350 3:42 eaton
Z28Owner is offline   Reply With Quote
Old 02-15-2005, 09:48 PM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Yes it can be done that way. Why are you wanting to though? Is it for towing?
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 02-16-2005, 12:16 AM   #3
Z28Owner
Z28Owner's Avatar
Well I just assumes that would be my cheapest way to run bags. I really like the look of the 4/6 drop , but I use my truck everynow and then, sometimes to haul a car, and I dont want the springs to be a weakness. I dont really care to lay frame and all that, pretty much want a level ride height and when I do sometimes haul something I am able to adjust the bags of possible. Just wondering what I would need to order. Like shocks and what kind of bags, lines, and valves.
1971 LWB Chevy C-10
350/350 3:42 eaton
Old 02-16-2005, 09:34 AM   #4
smokekiki
Mike
smokekiki's Avatar
Run a seperate line and fill valve for each bag.That way there isn't any air transfer in corners.Without having a compressor,just use schrader valves.
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires
smokekiki is offline   Reply With Quote
Old 02-17-2005, 12:39 PM   #5
TOYOTA61384
What smokekiki refered to as air transfer is going around a turn, all the air will come out of the outside bag and want to go into the inside bag, making body roll terrible. I guess if you had a good sway bay it would help, but both bags independant would be much better, and the preferred method.
Robert
TOYOTA61384 is offline   Reply With Quote
Old 02-17-2005, 07:51 PM   #6
Shane65
The front is where you really need to have each bag independant of the other for cornering purposes. The rear is not as critical unless you are pulling some high g's when cornering. I've often wondered about using four bags at the rear. They would be the small sleeve type. By varying the amount of air in the bags(by this I mean 55 psi in the one and 20 in the other as an example) you could really dial in the height and spring rate. You would have a wider range of options for height, spring rate and load capacity. The smaller sleeve type aren't too big in diameter and I'm sure wouldn't be big problem fitting them in. Extra cost for the sleeves and their control would add to the cost of a pair of bags but may be worth it. Comments anybody?
Shane65 is offline   Reply With Quote
