Decoding my 65 vin
CAN ANYONE HELP WITH DECODING MY 65 C20 VIN, THIS WEBSITE DECODING DOESNT WORK FOR MY 65 VIN, AND OTHER SITE I HAVE BEEN TO, DO NOT DECODE THE 65 EITHER.
MY 65 C20 BUILD http://67-72chevytrucks.com/vboard/s...d.php?t=483346 ......................_____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ |
Re: Decoding my 65 vin
I'll take a stab,,,
C= Conventional (2WD) 25= 3/4-Ton 4= Pickup 5= 1965 Z= Fremont assy plant 153451= Sequential Serial number DD probably stands for Delivery Date. The dealer could stamp this space if he wanted to with the date the truck arrived on the lot. Not many did. ![]()
CHEVY/GMC VIN DECODERS |
C 254 52153451 reads as follows C= 2wd 25= 3/4 ton longbed 127" wheelbase 4=pickup 5=1965 Z=Freemont assembly plant 153451 =53451th unit built Each year begins with serial number 100,001
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
Thank you guys, it's there anything to tell me what size motor came wirh the truck.
the 1965 engine options that im aware of for the c-10,k-10, c-20. k-20 were the 230 w/date codes TA, TE, TG 292 w/date codes UH, UT 283 w/date codes WA, WE. Ive heard of some late models that had 250, but not sure if factory...I know it was a 1966 option as was the 327.
What engine do you have now? If its a 6cyl, the stamp will be on a pad next to the distributor and if the v8 it will be forward of the right side cylinder head
#7 | |
The L6 to V8 conversion is fairly simple, so either could have come with the truck. What does your upper radiator mount look like? If its flat, most likely it came with a 6, if its raised most likely an 8
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer Last edited by 1963c-10; 01-03-2012 at 02:34 PM. |
There is nothing on the truck or VIN that will tell you what it came with. Rarely...you can find a factory build sheet on the underside of the seat. I would start with running the numbers on the block that you have. Im more familiar with the 60-63 models...so maybe somebody can pipe in, but sometimes towards the end of a model you will find the next year engines. The 327 was listed for the 1966 models, but was made from 1962-1969 and the 283 from 1957-1967.
