Question on spark plug resistor and also rust on chrome
Anyone tell me what this part bbn is called and its purpose. I am trying to look it up using the part name "spark plug resistor" but I can find anything that looks like it. It plugs into the passenger side valve cover and all it says on the part is spark plug. I was just curious what its purpose was and also if it needs to be on a PM schedule like everything else.
Also, Anyone know of a way to get the rust spots off of chrome? Can I sand it all down and then step sand it to make it polished again? There has got to be a way to refinish it. Just looking for tips. Thank you. |
Re: Question on spark plug resistor and also rust on chrome
Are you sure that isn't a spark arrestor?
The Older Generation
That looks like the positive crankcase ventilation valve (PCV Valve) to me. I have cleaned light rust off of chrome by rubbing lightly with 0000 steel wool. Some of that looks pretty heavy though. LockDoc
![]() Join Date: Dec 2014
I use a product called NEVR-DULL on that kind of rust, you'd be surprised.
DAVE Edmonton, Alberta 1959 Apache 1967 K20 1968 C20 1970 C10 1972 GMC 2500 1981 C10 |
Looks like a PVC vale to me too. You can also try SOS pads with soap in them. I personally haven’t tried them but I’ve seen others and it had good results.
![]() Join Date: Feb 2002
That's a PCV valve. No relation to spark plugs. Pull it off the hose and shake it. If it rattles, it's OK. If no sound, replace. They're cheap. Under $5 in Lower 48. You may be able to clean up the old PCV by shooting it out with spray carb cleaner.
In the Positive Crankcase Ventiliation system, oil vapors from the engine block are vented out a one-way valve [the piece in question] and reintroduced into the carburetor to burn again, while cool, clean air from under the air cleaner is sucked into the valve cover to replace it. I have used Flitz, a German metal polish, on rust on the grillle of my '71 Jimmy. In combination with steel wool, it should clear up. Follow up with a coat of wax to keep it from rusting again.
Every 25 years I like to rebuild that 292, whether it needs it or not. Last edited by '68OrangeSunshine; 06-03-2020 at 01:27 AM. |
You guys are awesome, thank you for clarifying both those questions. It rattles pretty good so I will leave it in place. Thank you all.
Brillo or SOS pads work well for pitted chrome. I had people tell me all the time "It will scratch your chrome". Well, I never saw any scratches and I figure the chrome is already shot so how can I hurt it arresting the rust's progress and making the piece look better?
#9 | |
![]() Join Date: May 2010
I replaced the PCV valve on my '69 350 sometime in the early 70s. I wasn't sure it needed replacement so I threw the original in my tool box where it still resides. It has "AC Spark Plug type CV-758C" stamped into it.
Jim |
Almost Satisfied
![]() Join Date: Mar 2002
Take a piece of aluminum foil and wad it up. Un-wad it and run it under water then hit the chrome. Takes the rust right off. I was doubtful too, but it worked!!
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021. "I can't complain, but sometimes I still do. Life's been good to me so far." |
20' Daredevil (Ret)
![]() Join Date: May 2003
When I tried aluminum foil, I had not heard of getting it wet first. Was not terribly impressed with my results using dry foil. I have had much better luck using 0000 steel wool like Leon mentioned.
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
I've used crumpled tin foil to clean the grates of my BBQ grill, but never the grille of a classic truck.
