Rag joint bolts
Does anyone know what size the bolts that hold the rag joint to the steering box are?
71 Chevy C10 Shortbed Stepside. LT1 with 4l60E. Just got back from painter, in assembly now. |
Re: Rag joint bolts
Buy it from lmc because their is only one bolt out of the 3 if i remember and be prepared to drill out the ones that aren't bolts unless you're taking out your steering column
Re: Rag joint bolts
The steering column is out and I just need the bolts. LMC doesn't have them separately. I thought if I could get the size I could buy them locally.
Re: Rag joint bolts
Just to clarify, I am looking for the bolts that hold the rag joint to the steering column shaft.
![]() Join Date: Mar 2012
Re: Rag joint bolts
Can you go to a parts store and check the Dorman (help) Section for the correct ones? I thought mine had splines in the shoulders,for a special fastener
if i remember right??? but do not quote me on that .....
Mike 72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider. 421 SBC / TH350 3000RPM Stall Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks ![]() |
![]() Join Date: Mar 2003
Re: Rag joint bolts
If you are talking the pinch bolt.....Factory uses a 12 point headed bolt. You can use an allen head style. 3/8'' fine thread, 1-1/4'' long , should be grade 8
Re: Rag joint bolts
save yourself the time and order the complete setup
