Old 09-29-2010, 08:03 PM   #1
frankyjoet
Red face crank pulley on 73 gmc 3/4 2wd
Ok, i want to know if you can use shims/washers behind the crank pulley? The reason for this is i have after market power steering brackets. billet. The pulley on the str pump doesn't line up to the crank pulley. The str pump pulley has 2 grooves. There is about a 1/2" behind the str pump. The crank pulley has 3 grooves. Any info would be helpful. thanks.
frankyjoet is offline   Reply With Quote
