09-18-2011, 08:38 PM | #1 |
Need some help on a bolt size
Wondering what the measurements are on a np205 for the bolt that bolts the shifter to the t-case. Much thanks.
http://67-72chevytrucks.com/vboard/s...d.php?t=429098 |
09-19-2011, 09:35 AM | #2 |
Active Member
Re: Need some help on a bolt size
Three different ones. 7/16 or 1/2 or 9/16 . From my experience.......Rick
09-20-2011, 12:12 AM | #3 |
How long about? If i remember right, if its too long it jams up the shifter.
09-20-2011, 07:48 PM | #4 |
Active Member
There is a shoulder on the bolt I believe that keeps it from being tightened to far. Unless there is an extra washer on the shifter side. Early ones had a bolt with a spacer on shifter side that fit over bolt instead could get tight if spacer was to short....Rick
