Old 12-25-2007, 02:24 AM   #1
D-Day
Live fast, die young
D-Day's Avatar
Water neck seal: Silicone or gasket, or both
Well, due to a rusty and pitted water neck, I replaced it with a chrome aftermarket one near two months ago, picked up a new gasket, and replaced it and yadda yadda. Well, even though it was cranked down tighter than snot (though not too tight due to aluminum Edelbrock manifold), it leaked ever so slightly; through the gasket. Apparently I forgot to use some kind of sealant with the gasket.
So, I have a new gasket and some water neck silicone seal, and the question is, can I use both, or should I just use the silicone? This leak is really annoying.
D-Day is offline   Reply With Quote
Old 12-25-2007, 03:12 AM   #2
NEVERENOUGH
NEVERENOUGH's Avatar
Re: Water neck seal: Silicone or gasket, or both
Take your water neck and hit it on the wire wheel of your bench grinder. Rough up the surface of the neck and you should have no more leaks.
NEVERENOUGH is offline   Reply With Quote
Old 12-25-2007, 06:54 AM   #3
xtreme80
Wishin' I had more money!
xtreme80's Avatar
In addition to the reply above mine, yes you can use both. I am.
xtreme80 is offline   Reply With Quote
Old 12-25-2007, 09:53 AM   #4
wedgemon
wedgemon's Avatar
I switched to an O-Ring style last year. No leaks at all.
- Dave
2003 Silverado K1500 Z71 - Arrival Blue
1973 K5 Cheyenne Blazer 350/TH350/NP203
Kids Trucks:92 K1500 Blazer 5.7/700R4 4" lift.
RETIRED: 1980 Scottsdale 4x4
Founding Member:
"TILT WHEEL BELLY." Club
wedgemon is offline   Reply With Quote
Old 12-25-2007, 11:52 AM   #5
Prong
- Dave
+ 1
Even though those gaskets are $5, they're worth every penny to me.
Prong is offline   Reply With Quote
Old 12-25-2007, 10:18 AM   #6
BLE 'BURBAN
In the Forgotten far North.
BLE 'BURBAN's Avatar
Chromed parts retain loads of heat and heat eventually will cause those chromed water outlets to warp. Then no amount of gaskets or sealants will keep them from leaking.
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015
1990 chevy suburban V2500 5.7L
My cluster Mods-Nov 2007
overhead console Stereo install Round 2 Aug 2009
Heated/turn signal mirror upgrade
BLE 'BURBAN is offline   Reply With Quote
Old 12-25-2007, 11:30 AM   #7
D-Day
D-Day's Avatar
Thing of it is, it leaked 5 minutes after I put it on. The surface of the neck and the manifold are just too flat/smooth to make a seal; no grooves like with the stock/steel one (neck or manifold).
I didn't think to get an o-ring; perhaps I'll ask when I pick up my Holley choke cable tomorrow. If not, then I'll scratch up the water neck, and use the silicone and gasket.
Old 12-26-2007, 04:13 AM   #8
63 & 64 Bowties
and a few others
- Dave
+2 they're great
You can't just get an o-ring, the neck has to be designed for an o-ring. It needs the o-ring groove in it.
Bill US Army Vet -193rd Infantry
BlueRidgeMuscleCars.com
“The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi
63 & 64 Bowties is offline   Reply With Quote
Old 12-25-2007, 07:20 PM   #9
Srubydo1986
The Crazy Machanic
Srubydo1986's Avatar
I used a plastic rubber gasket from autozone. look up one for a 89 jimmy that should be right used on my 86 (same style just different materal and its reuseable) ill see i f i can find a part number for u (ok part number is 35562T Pricing: $7.99 should be the one im talking about. it on a eldelbrock intake should solve ur problem)
*1986 Sliverado longbed 400 small block mean as hell, 700r4 trans (5 speed coming one day)
* 1970 chevelle 2dr sedan Latest update June 24 2007.
*1957 4 door stationwagon - pink all original needing a good restore (body great, floors bad)
newest additions
1965 shortbed fleet great granddads. Been told im nuts to bring it back from the dead (still going to happen) plans-all stock with a turbo 292 inline 3 speed column shift. and thats it
big block 427 and 5 speed trans and ford 9 inch theyhave no home yet thinking what to put them in
and a 79 c60 trash truck um no idea i have one
Srubydo1986 is offline   Reply With Quote
Old 12-25-2007, 09:11 PM   #10
D-Day
D-Day's Avatar
Hey, thanks. I appreciate it.
Old 12-26-2007, 05:09 AM   #11
D-Day
D-Day's Avatar
I think mine has that. I'll double check. Thanks for the heads up.
