71 front disk brake axle in a 70 K10
A while back I posted about upgrading my 70 K10 to power disks instead of drums. I've found someone who has a 71 K10 disk brake axle for sale localish for $250. Is it a worthwhile swap? I've got to determine the axle ratio and if the 71 axle is junk or not.
Paul
"You know that little thing in your head that keeps you from saying things you shouldn't? Yeah well, I don't have one of those" 1969 Mercury Cougar Standard 4 speed 1969 Mercury Cougar XR7 convertible 1970 4WD Chevrolet Suburban 1997 4WD Chevrolet Silverado Extended Cab Short Bed (purchased new January 1997) |
Re: 71 front disk brake axle in a 70 K10
Its worth it, atleast that's my opinion. That would be a direct bolt up. You would need to swap out your front brake lines, and your master cylinder to complete the swap.
I'm trying....
![]() Join Date: Oct 2013
100%. Do it....you'll be glad you did. Did the same to our '69. '71 was our donor too. Yes to break lines...prop valve too. And as you said, gears gotta match. But otherwise, an easy direct bolt up.
1970 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076 1969 K10 SWB CST http://67-72chevytrucks.com/vboard/s...52#post8520352 1971 K20 Z84 https://67-72chevytrucks.com/vboard/...90#post9047290 1946 B.F. Avery Model A Tractor http://67-72chevytrucks.com/vboard/s...55#post8292555 "Sometimes I wonder if zander208 was even real..." |
![]() Join Date: Mar 2003
1970 is already open knuckle, so if push comes to shove with the gear ratio, you can swap the knuckles out
#5 | |
![]() Join Date: Jul 2003
From the Blazer section:
1970 K/5 Blazer CST 4WD, Bronze, 93k ACT. miles, 350, 4 speed, positraction, 16.5" x 8.25" wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration in progress... ![]() 1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor... ![]() 2017 Sierra 1500 SLT 4WD, Black, 41k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2... 2019 Canyon SLT 4WD, White, 60k miles, 3.6, 8L45, 3.23 LS, 18" wheels |
Thanks guys!
Now the seller isn't sure what year the axle is from! Any links to how to identify the different years? Paul
This is the pic he sent.
All about them K’s
![]() Join Date: Jun 2014
If bet that is a 73+ setup based on the stabilizer mounting, it really doesn’t matter though it will bolt up just the same.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 ![]() |
![]() Join Date: Oct 2015
Even if the ring and pinion are junk or a different ratio than yours it's still the cheapest way to get disks. You can use the knuckles, spindles and rotors off the donor axle and swap onto yours.
I'm trying....
Also...if all else is good, but the ratio doesn't match, you could swap out your existing gear set into this axle.
![]() Join Date: Mar 2021
Great info guys, while we're talking about 1971 4x4 with disc brakes, who sells the dust shields for a 4x4 axle, thank you
All about them K’s
It seems those may have become hard to find. My dad had to repair the dust shields on his K20 last year because he couldn’t find new ones anywhere, online or even Napa.
Lmc should have k10 dust sheilds
Any pic a parts locally to you ? The nice k10 dust sheilds are steel I agree with 57taskforce i think its a 73 up diff it will still bolt in place thought it may need one shock mount relocated i seem to think 73 up front diffs have one shock in front and one in back of the diff |
#14 | |
All about them K’s
#15 |
Great info on the brake dust shields guys, I'll check the local pick-a-part as well ....... I didn't think of that, rust is a huge problem up here.
Gerry, North Bay Ontario 1971 Chevy K10 short stepper, 518 med green & white 1972 GMC C1500 long box, dark Brown, owned since 1977 1969 GMC C2500 manual |
#16 |
You can even use the later model 10 bolts if you want. I think the 88 -91s have 30 spline axles on the 10 bolts. Earlier 10 bolts have 28. I'm pretty sure the later dana 44s use axle shafts with bigger u-joints. 10 bolts are easier to swap gears in also. If you want Dana, I would look for a late 70s model.
#17 |
I'm trying....
Later model dust shields will work as well. You might try Torque King...they may have some in stock. 71-72 had the two piece welded (caliper bracket + dust shield) and later versions were the one piece stamped version. Here are pics of both.
#18 |
IronCanine perfect info man, thanks so much for the pics.
#19 |
In the pic he sent you there is a chance that it could be a 10 bolt looking at the plate across the shock mount
#20 |
I have not looked at the 77 blazer set in the back 40 since I cut them out 7 years back
Thanks 57 for clearing that up been thinking of using them in my 72 for a quick 3.73 gear change not sure how I will like the 3.07 gears in my dads truck 4x4ing |
#21 |
![]() ![]() Join Date: Sep 2008
