flywheel & starter engagement Problem
Put in a 98 vortez 350, installed a long tail 350 tranny. Noticed the hum of the starter during engagement. Pulled the flywheel cover the starter a latemodel with off set mount holes lack about 1 inch from meeting the flywheel teeth. I heard that an old model starter 50's?-60's starter is off set will correct the smaller flywheel. Anyone have knowledge off that sort or will I have to pull tranny & replace the flywheel??? Help...Thanks ohh and if another starter will correct this what year starter??
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
Re: flywheel & starter engagement Problem
Guess no one knows?????I can't be the first person to have run into this?
