![]() Join Date: Jul 2007
Can This be FIXED? Edelbrock Cross Ram manifold
Saw this at a swap meet today..... looks like someone over did it or DROPPED this Edelbrock Cross Ram Manifold.
Can this be fixed??? My concern is that the broken "ear" is in the front where the water jacket is. Need someone's EXPERT opinion????????
John aka "Milner" PA-IndianRider - Pittsburgh, PA 70 Chevy C10 Stepside "Gasser/Altered Drag Race Hot Rod" Where were You in '62 ? Last edited by PA-IndianRider; 07-19-2008 at 07:23 PM. |
Re: Can This be FIXED? Edelbrock Cross Ram manifold
I had a dart single plane intake that cracked on the front from tightning to specs, looks like the same spot. Called dart and they said to mail it in and they will send me another one, but they told me that they would repair it as if it was no problem. Does the guy have the piece that broke off?
#3 | |
Sent the pics to my cousin who works for Miller Welding and see what he says
John aka "Milner" PA-IndianRider - Pittsburgh, PA 70 Chevy C10 Stepside "Gasser/Altered Drag Race Hot Rod" Where were You in '62 ? |
Machine shops weld alum heads . maybe one could build up the weld on that and redrill the hole
nickle and dime |
60-66 Nut
That should be an easy fix for an experienced welder. I've fixed similar problems many times without the missing piece.
Ya that can be fixed easy, had that fixed before on the center bolts.
Speed is just a matter of money, question is how fast can you afford to go? 8.95@148.97mph all motor haven't tried bottle yet Sponsored by: Getz Oilfield Consulting Hard Candy Customs |
#7 | |
only to find out the "seller" did NOT return to the swap meet today..... Bummer!!! That's how my luck goes.... they'll be another swap meet at Canfield, Ohio again in the Fall (3 x a yr). So maybe I'll get another chance to score the "cross ram" I have always wanted.
Yup easy fix. Had a shop do something like that for an intake once.
