08-20-2013, 08:05 AM | #1 |
New Member Need Help
I just got a 1965 gmc stepside v-6 project need a lot of help #1 the truck has not been driven for 10 years motor is stuck I have taken he plugs out and filled pistons with deasel fuel letting it soak hope this will break it loose # 2
the left rear wheel locked up have no idea how to get it off does the brake hub come off or do I have to pull the axle. Which repair manuals would be best to buy for body repair , mechinal repair electric repair and what company to buy from? as you can see I am a poor speller is there a spell check on this site and how can I put on pictures at 74 I am a slow learner and a poor computer operator thanks for any help I and get Bob |
08-20-2013, 10:11 AM | #2 |
Re: New Member Need Help
Welcome Bob - the hub should definitely come off - likely just have some stuck shoes there... these guys will definitely hook you up with the resources to get you where you need to go - don't know a much better group of guys. Good luck on your build.
64 Step Side - The Mistress |
08-20-2013, 11:00 AM | #3 |
Senior Enthusiast
Hi Bob, welcome to the forum. I don’t have any history with stuck engines, so I’d suggest do a Google search on “how to free a frozen motor”. Here is a typical example with several different ideas:
http://www.hotrodders.com/forum/frozen-engine-2705.html Does your truck have 6 lugs or 8 lugs? Once I know which axle you have I can scan the appropriate pages from the 1960 Truck Shop Manual and that will probably be helpful enough to get the thing apart. By far the best overall manual I’ve purchased is a reproduction of the original GM Chevrolet Truck Shop Manual. It will help with all body, suspension, and electrical topics. I am not aware of any reproduction GMC manuals for a truck with the V6 engine. For assistance with that subject I would suggest joining the Jolly/GMC website, but only if you intend to keep the V6. The Jolly site is comprised of GMC V6 enthusiasts, so restorers are welcome, but engine swap guys are not. If you want to switch to a V8 (or anything else) the forum right here can offer the best information available. The Jolly site seems to be going through some web changes but here is the link: http://6066gmcguy.com/ If there is a V6 manual available the guys at Jolly’s will know and be able to direct you. I buy most of my vintage parts from Classic Parts (formerly Chevy Duty). They offer high quality, fair pricing, and good customer service. If you choose to purchase the Chevy Manual, you will need the 1963 Shop Manual and the 1964 & 1965 Supplements to cover everything. http://www.classicparts.com/Manuals/products/173/ Good luck!
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
08-20-2013, 08:09 PM | #4 |
I have a 8 lug wheel Question there are two flat plugs that have a slot for a straight screw driver to screw them out do I have to get them out before the brake srum will come off
08-20-2013, 11:10 AM | #5 | |
08-20-2013, 11:30 AM | #6 |
marvel mystery oil is the best thing for a stuck piston or rust in the piston. I have seen diesel fuel used before but dont know the merits really.
I will 2nd the Classic Parts of Markeb01, I have used them for 25 years. get the manuals, you will be glad you did, and dont forget the supplementary 64/65 like I did. Oh and dont worry about the spelling, we all speak and read the hieroglyphics of one another fluently. Good luck and Welcome!
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
08-20-2013, 04:34 PM | #7 |
Mine sat for 21 years and I turned it by hand before using the starter. Mine did not have a bolt on the crankshaft to break off so I remove the three bolts on the Harmonic Balancer bolted on a Puller and stuck a crow bar between the bolts on the puller to wiggle it free and make sure it spun ok before using the starter. Besides squirting oil down the spark plugs, I also removed the distributer and used a hand drill to spin the oil pump. If you pull off the vavle cover (insert oil here to) and don't find it full of rust you have a pretty good chance of getting it moving.
08-20-2013, 08:34 PM | #8 |
Should just pull off. I know that's easy to say but after 10 years of sitting its gonna take some effort! Save the v6 if possible they are work horse motors. I have a 305 v6 in my 1 ton and it cranked up and purred like a kitten after sitting since 1997. I even cranked it on the 16 year old gas lol good luck o by the way do you know what size v6?
Posted via Mobile Device |
