Old 08-30-2010, 02:32 PM   #1
Wildstreak
"something witty here"
Wildstreak's Avatar
57 4x4 drivetrain question
I was wondering if I swapped cross members and drivetrain from a 71 4x4 into the 57 would I have any clearance problems in between the cab and drivetrain? Basically I have a 350/4spd/np205 and would like to put it into my 57, other than cross members, would I have to modify anything else?
57 chevy 4x4
70 swb fleetside 4x4
68 burb 2wd:
71 burb 2wd: 350 4spd
71 lwb fleetside 4x4: 350/sm465/205/3.07 eaton posi rear
72 lwb fleetside Cheyenne 454/th400
1991 GMC V3500 CC 4x4
Wildstreak is offline   Reply With Quote
Old 08-30-2010, 08:28 PM   #2
OrrieG
OrrieG's Avatar
Re: 57 4x4 drivetrain question
axles will mount to the springs. See my build thread for other issues like crossmembers, etc. I kept the crossmember at the front spring rear shackles for frame stiffness but I have seen guys take they out. With the 4 speed it might not be an issue to leave it. If you pull the stock one I would replace it with some sort of cross member. Lots of room between the cab and drive train. Mine is 74 350/th350/np203
Old 08-30-2010, 10:57 PM   #3
Wildstreak
Wildstreak's Avatar
read through your thread, it gave me a good idea of what I want to do. I have a universal tubular engine mount Im going to use because I really dont like the look of the stock mounting.
Do you have any pics of your brake booster and how it is set up? I got this truck from my dad, at one time he had a guy start rebuilding it but he was just dicking around so we took it back. The trucks pieces are scattered and I dont really know what Im looking for lol.
57 chevy 4x4
68 burb 2wd:
Old 08-30-2010, 10:00 PM   #4
raycow
IMO it would be less work to keep the 57 bellhousing crossmember. The 71 bellhousing will mount on it like stock.
Ray
raycow is offline   Reply With Quote
Old 08-30-2010, 10:46 PM   #5
Wildstreak
Wildstreak's Avatar
Ray
the sm465 from the 71 doesnt have a bellhouse mount like the 57 tho, the mount is in between the tranny and transfer-case.
57 chevy 4x4
68 burb 2wd:
