06-14-2012, 10:28 PM | #1 |
GM ONLY BABY!!!
Heater box/Evaporator box refinishing
Ideas and pics for heater box refinishing please. I think I will just prime and paint it when I get my truck painted in a few weeks.
2 wrongs don't make a right, but 3 lefts do. 66 Chevelle Malibu 406ci, 573hp, 10.99@121mph 96 Chevy Silverado Z71 72 GMC 1500 Super Custom LS 6.0/4L65 on airride http://www.cardomain.com/ride/707879...mc-c-k-pick-up |
06-14-2012, 11:35 PM | #2 |
Re: Heater box/Evaporator box refinishing
subscribed.
1972 Custom Deluxe LT1 Gen V Swap "Green Lantern" 1984 Silverado Red Baron-72 c10 Project |
06-15-2012, 12:46 AM | #3 |
Collector of Projects
I was going to have mine rhino-lined ... but ended up just using a soft wire wheel and putting it back on...
06-15-2012, 12:54 PM | #4 |
I just did mine... new heater core, new gaskets, etc. Check the heater resistor while you have it out, it's easier to get at.
I wound up sanding the scratches out of it and painting it with Eastwood Underhood Black. Here's a tip: the heater core is held in by two thick wire supports that bolt in. My core was an aftermarket replacement that didn't fit tightly, so I slit a piece of fuel line lengthwise and slid it over those wires before boltiong it all back in. This held it in place without any movement and should prevent a lot of rattles in the future.
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
06-15-2012, 01:34 PM | #5 |
I washed/ cleaned off dirt etc rubbed Mastercoat black (this is like POR15 but I like it better) over rough surface this made it look like what I thought was original...
06-15-2012, 03:01 PM | #6 |
I had a broken heat box in my 70, I fixed the crack with fiberglass then sprayed it with a texture spray made by Plasticoat, it looks like bed liner but a little more coarse. I then sprayed it satin black. No pics but it really looked nice. I used the same stuff on the interior heater box on my 69 and 72. In the past I have coated similar items with a heavy coat of paint then dusted the wet paint with sand then another coat of paint. It really works well.
http://smg.photobucket.com/albums/v655/aaronhero/ |
06-16-2012, 10:11 AM | #7 |
1972 C10 LWB, 350/350 Deconstruction began 5/2009, mostly completed restoration, 5/2017 |
06-16-2012, 09:43 PM | #8 |
In both of my restorations, I took the box out and when no one was home gave it a scrub in the bath tub . After drying it I purchased some cast blast or similar cast iron colored paint (it is actually pretty close to the original finish on the box) sprayed the box , replaced the evap cores, used stainless screws to bolt back together new gaskets etc.
67 blue step side- bb 68 gold and white swb cst anniversary 68 custom swb hot rod Ls swap 69 swb cst 6 cylinder/ overdrive 69 black/black cst bb swb 70 orange and white cst Canada built truck swb bb 71 black and white super swb bb 71 red and white super swb 72 green and white super swb 4x4 62 nova wagon 400 series Ls swapped 68 Camaro 327/4 speed- 1 owner, original paint 66 Volkswagen bettle 69 auto stick Volkswagen Beetle |
06-16-2012, 11:02 PM | #9 |
06-17-2012, 05:53 PM | #10 |
They came unfinished stock. I just sanded mine down to fresh material and the painted it w/ semi-gloss clear, looks correct and brand new.
