Old 05-25-2010, 11:16 PM   #1
tranz am
tranz am's Avatar
whats the best rod and main bearings for the street?
Ive been going around in circles trying to figure out what rod and main bearings I should get for my 350 build. I first turned to my engine building book called ("small block chevy performance vol 1") and it says that i should look for a strong bearing with surface behavior a secondary consideration.
It tells me that Federal Mogal AP bearings, TRW CL-77 bearings, and GM Moraine 400 bearings are the best choice for strength but they require frequent oil changes because of poor embedability.
in the very next paragraph it says that for a pure drag race-race application the best bearing consideration is one with embedability and lists the best bearings ALREADY MENTIONED FOR STREET, Moraine 400 bearings, and federal Mogal AP bearings.
So basically it just contradicts itself leaving the question totally unanswered.
I searched all over the net only to find no real "best suited street bearing". So now i turn to u guys for advise.
thanks.
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=456220
Best 1/4 mile time 12.1 @ 111 w/traction issues
1969 GMC SWB
1964 chevy II Nova ht
tranz am is offline   Reply With Quote
Old 05-25-2010, 11:29 PM   #2
tranz am
tranz am's Avatar
Re: whats the best rod and main bearings for the street?
So far Ive found,
tri metal copper-lead alloy,
aluminum alloy,
Duroshield coated alloy, H14,
Bi metal silicon aluminum,
Tri metal, TM-77,
Bi metal aluminum alloy
Alecular silicon,
Lead indium,
Tri metal copper-lead nickel
thats a lot of different materials to chose from???
so far Im leaning towards these.
Federal Mogul Z82555CP10 - Federal Mogul CP-Series Rod Bearings
and
Federal Mogul Z4663M10 - Federal Mogul Main Bearing Set
they both have the classic Tri metal copper-lead alloy.
they are cheap so its questionable weather these can handle 400+ hp
My build thread
1969 GMC SWB
Old 05-26-2010, 08:47 AM   #3
1968SWBBigBlock
Active Member
1968SWBBigBlock's Avatar
Look at king brand bearings
http://www.kingbearings.com/
speak with the tech guys at king bearings - they seem to have the best bearings on the market currently
1968 SWB
454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts
781 heads Ported with 2.19/1.88 SSTvalves
Lunati 60204 cam, Micro Trol lifters,
Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition
Holley 770 Street Avenger carb,Headers armor coated
Built by Watson Ruppel Performance in Sarahsville Ohio.
Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall
12 Bolt Eaton Posi 4.10 Richmond Gears moser axles
18.5" x 31" Hoosier Pro Street Radials
ET Classic 5 Wheels - polished
Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone)
Custom Paint & Body Work
Special thanks to my wife, my son and my money tree
1968SWBBigBlock is offline   Reply With Quote
Old 05-26-2010, 09:49 AM   #4
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Clevite 77's have been the standard for years. I never really worried all that much about bearings. My machine shop always included them in a rebuild... and they've always been Clevites's.
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 05-26-2010, 11:06 AM   #5
tranz am
tranz am's Avatar
I'll look into both of those. thanks guys
My build thread
1969 GMC SWB
Old 05-26-2010, 12:43 PM   #6
tranz am
tranz am's Avatar
I took a look Clevite 77's and it looks like they are fully grooved bearings. Im trying to stay away from those because I hear that they wear quicker and arnt quite as strong.
Gary
My build thread
1969 GMC SWB
Old 05-26-2010, 12:48 PM   #7
GASoline71
GASoline71's Avatar
Don't overthink this... I have used those bearings in engine rebuilds for over 25 years... and have never had a bearing failure that was the bearings fault. Always from lack of oil, or other mechanical faliure...
From street/strip engines, to bone stockers... no probs.
Gary
Old 05-26-2010, 10:30 PM   #8
Camaro_nut2001
Chevy Lover Till The End.
Camaro_nut2001's Avatar
Gary
X2 on the Clevite's but I buy my own and install my own after the machine work.
1969 Chevy SWB Big Block - Under the knife as of 12/26/2011
1989 Chevy Silverado, 4X4 - Daily Driver
1996 Chevy Suburban K1500 - 4-Wheeler, Campin Truck
1968 Chevrolet Impala Sport Coupe - 327/350hp, TH400, all original.
Members I've met: BamaBaxter,
My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=500359
Camaro_nut2001 is offline   Reply With Quote
Old 05-26-2010, 11:03 PM   #9
Beuford
Beuford's Avatar
x3 on the Clevite's. I've been building engines for years and always use them in my own. Sometimes people bring me a rebuild kit and say they want something else and since it's their money I put whatever they want in.
Beuford is offline   Reply With Quote
Old 05-26-2010, 11:27 PM   #10
Bob 68327
72 Chevelle Club
Bob 68327's Avatar
I have spun my Clevite's 7500 many many times with no problem and I make over 400 hp. I also used them in my drag car for years.. My 2 cents....
I Have The Right To Remain Silent,But Lack The Ability
1972 Chevelle ... Mine
2006 Trailblazer... Hers
2002 Buick century ... Kids
2002 K1500 Z-71 EXT CAB ... Daily Driver
2005 Rockwood Roo ... For Camping
1974 Harley-Davidson XLH Sportster 84'' stroker
Bob 68327 is offline   Reply With Quote
Old 05-27-2010, 01:36 AM   #11
GASoline71
GASoline71's Avatar
Me too... I have just always got my engine rebuild kits from my machine shop guy... he just tosses everything in a box for me, and away I go to put it together myself.
Gary
Old 05-26-2010, 01:02 PM   #12
ProStreet68SB
The Engine Whisperer
ProStreet68SB's Avatar
Put in another vote for king bearings. Thats what i'll be putting in my pretty wicked budget small block
ProStreet68SB is offline   Reply With Quote
Old 05-26-2010, 01:06 PM   #13
GASoline71
GASoline71's Avatar
Don't get me wrong... I'm not sayin' that Clevite's are the "best" bearing out there... but for a street driven daily driver... your options for bearings are pretty easy to choose.
Gary
Old 05-26-2010, 10:40 PM   #14
hatchaddict
i use king bearing also i started using them im my honda engines that i spin to 9700 rpm and have never had a bearing failure. go to king site and read about there bearings and compare them to others and see what you think. iused to use clevite in my sbc builds till i discoverd king
hatchaddict is offline   Reply With Quote
Old 05-26-2010, 11:35 PM   #15
trusty72
trusty72's Avatar
i say king also but honestly on a street engine any good one will do, look at the engines in my sig and profile they both have Kings in them and after 100 drag strip passes they usually look like new.
1972 super cheyenne
1970 Suburb
trusty72 is offline   Reply With Quote
Old 05-26-2010, 11:36 PM   #16
Jacfourteen
Big Red - Now its a SWB!
Jacfourteen's Avatar
another vote for clevites
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread
41 3/4 ton (wife's)-flatbed, fully restored to original
01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's
02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's
Jacfourteen is offline   Reply With Quote
