frame problem
do you think i shoud replace the single frame rail, complete frame, complete front section or ? the frame has a crack that someone put bird crap welds all over.
""A bagged vehicle is only as good as it's wheel/tire combo!" -getlowness! my build thread http://67-72chevytrucks.com/vboard/s...=223747:metal: I'M SO SO CAL! ![]() Last edited by 69face; 04-26-2006 at 04:08 AM. |
Iron Thunder
Re: frame problem
i would say cut the bad pach out and repach it wright, my 2 cents.
Professional Grade
Re: frame problem
What year is the truck, and is it a 4x4?
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
#4 | |
Re: frame problem
""A bagged vehicle is only as good as it's wheel/tire combo!" -getlowness! my build thread http://67-72chevytrucks.com/vboard/s...=223747:metal: I'M SO SO CAL! ![]() Last edited by 69face; 04-26-2006 at 04:01 PM. |
Re: frame problem
JC Whitney sells a repair panel for that area. The paticular area is prone to cracking due to the excess stress from the steering componets.
http://www.jcwhitney.com/autoparts/P...000644/c-10614 It says 4x4 only but it should give you some ideas for repairing your frame Hope this helps Shane
1993 K1500 350 5 speed ![]() 1985 K10 Silverado Vortec 406 5 speed (in body shop) "I been drivin' this '85 pickup truck Them buddies of mine call it a bucket of rust She's a little beat up but she still runs like the wind Yeah, kinda like me I been banged and bruisedBeen around the block a time or two But I'm runnin' like new goin' places I never been No, I ain't broke I'm just broken in" 1963 Dodge Townwagon(its amazng what 30 years and zero miles will do to a vehicle ![]() Member#20327 |
Professional Grade
Re: frame problem
Yeah, its common for a 4x4 to crack there, but I've never seen a 2wd crack before before...
The frame rails between the 74 and the 86 should be the same, less the very front of the rail where the bumper bolts on.
A little east of nowhere
Re: frame problem
Find a heavy truck repair shop with a licensed welder on staff. My industry is used to repairing/modifing frames.
68 C10 250 4spd 69 C20 327 4spd 69 910 250 3spd 80 K10 350 4spd 76 C60 366 5spd school bus "THERE'S NOTHING YOU CAN BREAK THAT SOMEONE CAN'T BE PAID TO REPAIR" |
Re: frame problem
""A bagged vehicle is only as good as it's wheel/tire combo!" -getlowness! my build thread http://67-72chevytrucks.com/vboard/s...=223747:metal: I'M SO SO CAL! ![]() |
Re: frame problem
well i said i would update so here are progess pics. these are of the frame rail that i am using. it is a little shorter, but it has to work, because i went to two wrecking yards and there was one frame between the two that had already been cut. fudge!!
""A bagged vehicle is only as good as it's wheel/tire combo!" -getlowness! my build thread http://67-72chevytrucks.com/vboard/s...=223747:metal: I'M SO SO CAL! ![]() Last edited by 69face; 05-20-2006 at 02:34 AM. |
