Old 05-06-2012, 09:07 AM   #1
jason7698
Short water pump issues?
I just got my bbc (454) in my 71 c10 and have ran into an issue with the clutch fan. I will have to go to a swp and pulleys if I run the swp and clutch fan set-up (clearance issues with the new rad). If I stay with the long water pump I will have to do away with the clutch fan and run electric fans. I know it will be cheaper to go with the electric fans and keep my lwp but I think it will cool better with the swp and clutch fan set-up?...What should I do?
jason7698 is offline   Reply With Quote
Old 05-06-2012, 10:34 AM   #2
cdowns
cdowns's Avatar
Re: Short water pump issues?
move engine back radiator foward
Old 05-06-2012, 11:02 AM   #3
Willys47
Willys47's Avatar
go with the short pump and the pullys will need to change as well , but thats is what I did when I when bb
I was hooked on these trucks since 1982 when I drove my budys fathers 1968 Custum GMC 396 automatic dana 60 rear with a power lock diff what a ride more fun then we will we can ever tell!!
Willys47 is offline   Reply With Quote
Old 05-06-2012, 05:49 PM   #4
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
All the engines in these trucks came with short pumps from the factory.
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
