Old 04-22-2005, 01:15 PM   #1
70blazerpickup
frame question
is the 1/2 ton long wheel base 2 wheel drive frame the same as a 2 wheel drive 1/2 ton panel?
70blazerpickup is offline   Reply With Quote
Old 04-22-2005, 01:28 PM   #2
Joe67
67 is sold
Not sure on the LWB pickup but the wheelbase on my 67 c10 panel is roughly 127"
Joe - Formerly 67c10step
1967 Chevy Stepside - ECE 4/6, fuelcell, 5lug - SOLD
gr8lakes - My ebay auctions
Click here to order forum apparel :: Click here to become a subscribing member
Joe67 is offline   Reply With Quote
Old 04-22-2005, 02:59 PM   #3
Rod
The rear cab mounts on the frame will be different but can be swapped over after taking rivets out. The box supports on a top of the rear part of frame are also different than panels..again it can be changed. The frame are basicaly the same...only 4wd frame swap or a leaf spring rear diff would make you have a little more difficulty, but you seem to be chatting 2wd so it should be alright.
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
Old 04-22-2005, 05:57 PM   #4
pjmoreland
pjmoreland's Avatar
I think the rear of the chassis rails might be different. I believe a sport bumper attaches directly to the back of the chassis rails without brackets on the panel.
pjmoreland is online now   Reply With Quote
Old 04-22-2005, 10:21 PM   #5
pritch
pritch's Avatar
That's right. I know this because some P/O cut the last 4" of my frame off with a torch, I suppose to remove the bumper
I have a doner frame, so when the time comes I'll replace the frame ends. My bumper is just micky-moused on right now. That frame is 3/4 ton, though, and I think there are some differences between it and the 1/2 ton.
'68 Panel
Project Boogie Chillin'
'68 C-10
Ol' Green
pritch is offline   Reply With Quote
Old 04-22-2005, 07:07 PM   #6
chief bobber
Sanity is a state of mind
chief bobber's Avatar
That you Austin? IF so, I'm going to come by on sunday and take some pictures of the butt end of the 67 two wheel and compare to the back of my panel.
67 K-10 8ft step 250/465/timken 4 shaft/373 to 1
70 C-10 Panel Vortec V/5spd BW od /307 to 1
70 C-30 9ft stepside dump 350/465/ posi
and a few too many other trucks, cars, jeeps, cruisiers, and M/Cs
...o~`o
chief bobber is offline   Reply With Quote
