01-23-2015, 09:30 PM | #1 |
Need help wiring the 2011 Alternator
I am trying to finish up my wirings. The wirings came from 2001 truck. I picked up a 2011 160 amp alternator. The plug from the wirings did not fit, so I had to order a new plug for the alternator. I don't know which one to splice together as the colors are different. Please help.
01-24-2015, 01:09 AM | #2 |
Re: Need help wiring the 2011 Alternator
Unfortunately a 2011 alternator has a 2 pin regulator and doesn't lend its self to swaps because it needs a GBCM (Generator Battery Control Module) and BCM (Body Control Module) to function properly.
Here's a copy of a post I made on the trifive message board on that subject when I put an '07 5.3 in my '57 BelAir. If you've still got questions let me know... Quote:
01-24-2015, 09:09 AM | #3 |
Thanks for the reply Dayj1. I actually found your post earlier before I ordered the plug. I just didn't want to change the regulator. Looks like I have to do it now.
03-13-2015, 08:49 AM | #4 |
I want to thank dayj1 for this post. I did this with some variation and it worked out fine. My alternator is a DR44G ( 2007 GMC donor ). The guy at my auto electronics shop was super and told me to use a 23012211 regulator and I bought the 4 pin plug also. He gave me some tips on getting the lug off to remove the old regulator ( says he does hundreds of these for different applications ). You don't want to get too aggressive or you will break the plastic plates underneath. Once that popped off I unsolered the connector and installed the new regulator. The contact fit over the old pin so all I had to do was resolder the joint. No alteration to the case, Just cut the plastic cover for the 4 pin plug. Hooked the yellow wire to the exiter wire from the main harness and the main wire to the starter. I have the Classic Industries dash cluster with a volt meter and it registers 13+ volts. Hope this helps someone else.
tbrown's 56 Cameo Build |
03-15-2015, 11:37 PM | #5 |
I have some questions about this...
I have an '04 truck PCM, Needing it to control a 2011 5th gen Camaro alternator (Valeo FG15S027 150amp), It has a 2-pin plug similar to a D44. The '04 PCM controls the voltage regulator through a "Field Duty Cycle" wire, And a "Indicator Control" wire, Looking at diagrams for a 2011 Camaro, It also has the same circuits. At this point I'm doing research, I wish I had rigged the Camaro alternator on the Burb & tested it before pulling the engine, But I didn't. I don't see an issue with wiring this alternator "Circuit number" to "Circuit number"? Not concerned with a charge indicator lamp in the dash, I have a volt gage. '04 LM7 alternator diagram. |
03-15-2015, 11:40 PM | #6 |
2011 V8 Camaro alternator diagram.
03-16-2015, 12:17 AM | #7 |
03-16-2015, 12:37 AM | #8 |
Thanks! Why couldn't the OP do the same thing? The '01 truck diagrams show the same.
05-29-2018, 12:56 PM | #9 |
Bumping an old thread. Did you ever figure this out? Check this article out: http://www.flatrater.com/samples/Battery/rvc.html
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
