05-12-2014, 08:41 AM | #1 |
Starter Will Not Engage
72 1/2 ton, big block. Been parked for several years. Put a new battery in and turned the key, but no starter action..nothing. There's power to the ignition system when the key is in the run position. I'm thinking neutral safety switch. Had an old 72 Cadillac that did the same thing. Thoughts?
And yes, before I tried to start the engoine, I made sure that it spun and pulled the plugs and squirted some lubricant in the cylinders.
1968 Custom SWB, 327/3 speed OTC 1969 CST LWB, 402/400 1970 CST LWB, 402/400 1970 Sierra Grande LWB, 350/350 1971 Cheyenne LWB, 350/350 1972 Cheyenne Super LWB, 402/400 1972 Sierra Grande LWB, 402/400 1979 Silverado LWB, 350/350 1984 Suburban 1990 454 SS 1991 Silverado, X-cab, 4.3/5 speed Getrag 2005 Silverado Crew Cab Corvettes: 75, 77, 78, 93, 96 |
05-12-2014, 11:00 AM | #2 |
Re: Starter Will Not Engage
See if you have power at the purple wire on the starter solenoid while cranking. If not it's farther back.
68' C20. 283CI w/55CC 305HO heads, NP435 Close Ratio, Corp. 14 bolt FF 3.21, 75' front end swap (everything but the X-member). |
