Old 02-26-2009, 11:11 PM   #1
1970CustomC10350
4spd. Linkage??
Hello All, I've been working on replacing a dying 327 with a 400 in our 72 3/4 ton. When I was at it I noticed that the clutch lever on the frame seemed to be at a considerable angle, as in not perpendicular to the frame. Is this normal? I haven't found a decent schematic or picture of this yet. The part I'm talking about rides on two ball studs, one mounted on the frame the other on the engine block. This truck has been monkied with quite a bit by previus owners so there really is no way of telling what combination of parts we got. It does have headers so I'm wondering if some tweaking was involved to everything work. It might be perfectly normal too. Does anyone have a decent picture of what factory 4spd. clutch linkage for a small block is supposed to look like? It seemed to be working O.K. before I started but if its not right I want to make it right. What do you guys think? Any help is very appreciated?
1970CustomC10350 is offline   Reply With Quote
Old 02-27-2009, 12:28 AM   #2
dan42
dan42's Avatar
Re: 4spd. Linkage??
Pictures. Pictures. Pictures. You are also going from a small block to a big block.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD
Click here to support the board
Philippians 4: 6-7
dan42 is offline   Reply With Quote
Old 02-27-2009, 11:48 AM   #3
1970CustomC10350
Re: 4spd. Linkage??
I'm sorry, I'm replacing the small block 327 with a small block 400.
Old 02-27-2009, 10:59 PM   #4
1970CustomC10350
Re: 4spd. Linkage??
Still thinking on this issue. I might have to run out to a bone yard and see if I can find a V-8 4spd. to look at. Are the factory linkage brackets mounted to the frame with rivets or bolts?
Old 02-28-2009, 12:01 AM   #5
airdale94
airdale94's Avatar
Re: 4spd. Linkage??
The ball stud on the engine doesn't go in either of the holes on the engine. There is a flat piece of metal that bolts in the holes then the ball stud screws into the plate. It almost looks "homemade" and you could probably fab one pretty easy. The bracket on the frame is riveted. But can be bolted. Make sure if you obtain a donor that you put it on facing the right way or it will bind. 6 cyl. stuff is not interchangeable, except for the frame bracket.
airdale94 is offline   Reply With Quote
Old 02-28-2009, 12:01 PM   #6
1970CustomC10350
Re: 4spd. Linkage??
Thanks for the reply. Yeah I got the engine bracket except someone welded the ball stud to it instead of bolting it on. When you say, "Make sure if you obtain a donor that you put it on facing the right way or it will bind." are you refering to the bracket on the frame?
