Old 08-28-2006, 10:29 PM   #1
Shane
Shane's Avatar
Shrader valves ... where to buy?
Where did you guys find them ... I need a few for a temporary fix ... gotta move a bagged truck that isn't plumbed or wired.
Thanks gang.
Shane is offline   Reply With Quote
Old 08-28-2006, 10:32 PM   #2
EyeH8the24
EyeH8the24's Avatar
Re: Shrader valves ... where to buy?
i got mine a big rig parts place...
EyeH8the24 is offline   Reply With Quote
Old 08-28-2006, 10:34 PM   #3
71swb4x4
71swb4x4's Avatar
I bought mine at the local Car Quest. The farm supply store has them too.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 08-28-2006, 10:39 PM   #4
Alvin
Never Done?
Alvin's Avatar
DO NOT DRIVE ON THIS. YOU COULD KILL YOURSELF OR A BUS FULL OF ORPHANS
I walked into Wal-mart's tire dept. and said I needed two used valve stems. The guy reached in the box and handed me two brand new ones. I said thanks and walked out.
Came home and tried to cut as much of the rubber off the bottom as possible. Then I removed the valve cores and burned off the remaining rubber with a torch. Let them cool and scuffed them with a bit of sandpaper.
What I was left with was just about a perfect fit for 3/8" air line. I heated the valve stem (core removed still) and inserted it in the line and squeezed the air line onto the hot valve stem. Reinstalled the valve core and tried them out. They seemed to hold air pretty well then, and this was back at the beginning of June. My airbags are still holding up my empty frame today. Haven't added a single bit of air since June, and I can't tell any difference.
I'm not sure how well it would work with the higher pressures that are needed to raise a *more* complete truck, but it was free and it's pretty hard to beat that price.
*edit* went down to the garage to get a picture of what I ended up with.
Ethel - The Legend Continues...
Ethel has been sold.
Last edited by Alvin; 08-29-2006 at 08:31 AM. Reason: added death warnings and disclaimers
Alvin is offline   Reply With Quote
Old 08-28-2006, 11:21 PM   #5
hotrodhomi
hotrodhomi's Avatar
^^^ this might be OK for getting your truck from one end of the shop to the other , but there is no way I would drive on that.
'72 2wd blazer, bagged w/ watts link & EDC
'72 C10 "Lowered Farm Truck" STOLEN 5-18-11
'66 impala ht
hotrodhomi is offline   Reply With Quote
Old 08-29-2006, 12:43 AM   #6
camaro__thunder
Epoxy Primer Friendly
camaro__thunder's Avatar
Oreilly Auto Parts has the male threaded ones for around $2...
My Project 69 SWB
SHAVED BAGGED DOORED
camaro__thunder is offline   Reply With Quote
Old 08-29-2006, 08:26 AM   #7
Alvin
Never Done?
Alvin's Avatar
Oh yeah, sorry. Never meant for it to sound like I endorsed driving on them. As far as I can remember Shane's truck isn't driveable just yet, so I didn't think to mention that. That is just my rigged way of being able to get my frame up out of my basement level garage, aired out there's no chance of it making it up the hill. I would never drive on that either.
Old 08-29-2006, 03:57 PM   #8
Shane
Shane's Avatar
Thanks gang. I will check with O'Reilly's.
Old 08-29-2006, 04:28 PM   #9
svgould
Active Member
svgould's Avatar
Ace Hardware also carries them!!
1971 SWB SOLD
  • LT1 motor / 4l60E transmission
  • ECE front dropped spindles with stock height springs
  • 4" rear springs
  • Coys Wheels 18 x 8 all the way around
  • Hydratech hydroboost brake system
svgould is offline   Reply With Quote
Old 08-30-2006, 09:39 AM   #10
Shane
Shane's Avatar
found them at O'Reilly's here locally. They are called Tank Valves with 1/8" NPT threads. $1.99 each ... link below.
Tank Valve
