Old 09-09-2003, 10:04 AM   #1
Ackattack
Ackattack's Avatar
New center console
Well I'm just about finish with my new center console. I had to make it in two pieces so that it would slide under the dash.
The back part that you can't see houses a 10" sub and amp. It also covers the fuel tank in a fashion inspired by the waterfall in the corvette convertables.
The original plan was to put a trans temp gauge on the flat part under the AC controls, but I may end up putting a 10 disk changer there instead...haven't decided.
Ackattack is offline   Reply With Quote
Old 09-09-2003, 10:13 AM   #2
70c10
67-72 Addict!
70c10's Avatar
Very Nice job!
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 09-09-2003, 11:04 AM   #3
Hotrod70C10
Low & Slow
Hotrod70C10's Avatar
I like it! That is basicly the route that I will be going, Whenever I get around to it. btw, How much does that b&m shifter run?
70' C-10 LWB Fleetside
4.5/6 drop
Hotrod70C10 is offline   Reply With Quote
Old 09-09-2003, 11:43 AM   #4
Ackattack
Ackattack's Avatar
Ah, I think it was about 150. I got is like 2 years ago. I liked the idea of a floor shifter, and the linkage in the column was old and worn out. You'd pull it back out of park, and it'd basically fall into first.
Old 09-09-2003, 11:54 AM   #5
Yukon Jack
Yukon Jack's Avatar
Looks real good. Cd player would be great in that location.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 09-09-2003, 10:21 PM   #6
tyger25
tyger25's Avatar
Really nice! I wondered how that would look!
U.S.A.F.
68' C-10 Stepside
305 w/ 4 speed
tyger25 is offline   Reply With Quote
Old 09-09-2003, 10:36 PM   #7
Dusti
Not Dusti,just Bob
Dusti's Avatar
Post
Looks good to me.
72 cheyenne super 1/2ton
89 camaro
Dusti is offline   Reply With Quote
Old 09-09-2003, 11:02 PM   #8
Zurbo
Zurbo's Avatar
Looks really good! You could put in one of those LCD screens as well.
Zurbo's Chevy - 1972 Black/White Cheyenne Super. 402 Big Block /THD 400, factory air and tilt.
My other Chevy - 1998 Camaro SS
Zurbo is offline   Reply With Quote
Old 09-09-2003, 11:07 PM   #9
Hotrod70C10
Low & Slow
Thanks for the info!
4.5/6 drop
Old 09-10-2003, 08:42 AM   #10
Ackattack
Ackattack's Avatar
I don't think that would get approved by the boss.
