BlahBlahBlah
3/4 axels vs 1/2
If you swap axles from a 3/4 ton to a half ton is it just a matter of bolt in? Brake lines, emergency brake cable, spring pads ... assuming its all from the same year truck?
user # 2756
![]() Join Date: Jun 2001
Re: 3/4 axels vs 1/2
I think the fronts are easier to swap. Because the front u-joint is still a 1310. In the rear you will need a conversion u-joint to go from (typically) 1310 or GM-3R (at TC) to a 1350 (at rear end). On my K5 with the CUCV 1 ton rear 14 bolt, it looks like the e-brake cables will work with the 1/2 ton stuff. The rear brake hose should work.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs 1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX 1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears 1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now..... 1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone. 1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed. 1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm ![]() |
user # 2756
One more thing, a 1 ton rear will need spring perches and shock mounts relocated. Not the 3/4 ton though,
#4 | |
What years you referring too?
'81 K20 Silverado , '99 Dodge Cummins 4x4, '05 Dodge Cummins 4x4, Pinstriping-Lettering-Specialty Painting |
user # 2756
The 1 tons spring perches are at 40.5" apart, the 1/2 and 3/4 ton are 42.5" apart. Years would be between 73 and 87 (91 for blazer/burb/k30) Also, on the 1 tons the shocks are on the inside of the frame while the 1/2 and 3/4 tons mount on the outside of the frame and are staggered different.
BlahBlahBlah
On my deal Im talking 72. So basically drive shaft stuff.
Guy down the road has a '79 or '80 c/30
Gonna go pay a visit with a tape measure
