what is it?
what is the solinoid for on the right side of a q-jet used for? what does the wire hook up to? it looks to me like it is to idle the engine up while the a/c is running. the truck i saw it on was in the salvage yard and did not have a/c. pn 500 in the pick
1972 C-10 SWB 350CI TURBO 350 TRANNY, TILT, POWER WINDOW & BRAKES, TANK UNDER THE BED W/MARKER LIGHT FILLER. 3.08 GEARS, CLASSIC AIR ![]() ![]() 2000 chevy blazer 1990 nissan pick-up 1984 mazda pick-up (son's project truck) |
![]() Join Date: Jul 2005
Re: what is it?
May be fast idle used when first starting the engine ?
The biggest problem people have, is other people Thou shalt be cool and not hassle ![]() Be a site supporter. ![]() The heart of the wise inclines to the right, but the heart of the fool inclines to the left." Ecclesiastes 10:2 |
Re: what is it?
I believe that is the electric choke - I could be wrong though.
Caleb |
It's a catastrophic success.
![]() Join Date: Jan 2003
Re: what is it?
Self-proclaimed LED man
Re: what is it?
it will idle the truck up when you switch the A/C on. Say if you are in a parking lot and switch it on, the solenoid would idle the truck up so the a/c wouldnt kill it. my truck has one, but im pretty sure it doesnt work lol
My LED Website My Photobucket Album of LED's Ask me about hand-made custom L.E.D brake and reverse lights. <- LINK I also do LED: -Third Brake/Cargo -Brake (truck and burb) -Reverse (truck and burb) -67-68 Front Turn Signals -69-70 Front Turn Signals -71-72 Front Turn Signals -GMC Front Turn Signals I can also do custom lights for other vehicles....i did a set for a AMC Gremlin once ![]() Norwood Survivor Last edited by 724x4a/cchevy; 02-08-2007 at 04:46 PM. |
its all about the +6 inches
Re: what is it?
I'm not certian, I think it is an anti-dieseling solonoid. Turn on the ignition, and it kicks on. The engine will use this as a throttle stop on the idle side of the throttle range. Turn off the ignition switch, and it retracts, shutting the butterflies allt he way. Helps to prevent run on, or dieseling. Early smog control stuff.
