Tracking arm bushings -
Does anybody know if there are two different sizes of tracking arm bushings? I ordered some from one of the site supporters but they're too big. My truck is a half-ton '67 and the the tracking arm looks original.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD ![]() Click here to support the board Philippians 4: 6-7 |
Dave's not here, man
Re: Tracking arm bushings -
I figured they were all the same size??
- 2014 VW Jetta - 2015 VW Jetta - 1966 Ford F-250 |
Unless what they sent me are not tracking arm bushings. I need to post a picture.
![]() Join Date: Aug 2003
3/4 ton has a larger one if I'm not mistaken.
Well, I called Energy suspension, and uncle is right - there is a difference between 1/2 ton and 3/4 ton bushings, and the 3/4 tons are bigger. 1/2 tons are part #2065, I got #2376.
Spanked once
![]() Join Date: Oct 2006
Don't know of the sizes but I did have to press mine in using c-clamps and wood, Then the brackets underneath had to be tweaked out from where they were tightened before to get them in. Mine are poly.
Mine were good & tight. I also spent a bit of time w/ a large C-clamp.
85' CUCV M1009!!! The newest addition! 6.2diesel, Th400, NP208, & only 36k miles! 70' C-10 LWB Fleetside - Looking good these days! ![]() 05' Dodge Neon 88' Winner Escape Sport 1750 - 4.3v6 94' Seadoo SP 84' Honda TRX200, bare nekkid. Just a frame & tires. Always looking for another project or any good deal! ![]() |
Here's a smmmmoooooth way to get them started into the brackets - no banging or busted knuckles. Just turn the nuts out and it'll spread easy and not bend anything either.
"A cat will almost always blink when hit between the eyes with a ball peen hammer" (you don't always have to state the obvious) Wear your PPE! You can eat with false teeth but you can't see with a false eye. 1959 Studebaker Silverhawk 350/400 1972 C10 L6 3OTT 2005 F350 - Built - whew! |
That's a great idea - thanks -
I was talking about the panhard bar that bolts to the frame and the rear end. never knew these were different also.
