ls1 swap question
i currently installed a 5.3/4l60e setup in my 68 and im to the point of plumbing the fuel system. My question is there another alternative to running fuel lines besides using braided hose? I know there is fuel injection hose but would it be hold or should i even trust it running from the rear tank all the way to the front. Also i know there is a aluminum lines u can buy but im not sure the rating on them. any info would help alot btw i have the cpp rear mount tank
Truck and auto performance nut
Re: ls1 swap question
you can run hard lines like stock. You can also get them in stainless. 3/8" feed line, 5/16 return if you need one.
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
Who sales the stainless line?
I'm curious about the stainless hardline too...
And just wondering, why are you against the braided line?
get it! |
Dorman makes a barb adapter for the supply and return line of the 5.3 fuel rail. Should be able to get it at your local parts store. You can also buy high pressure rubber fuel hose for the supply and the return can be standard rubber fuel hose. I've been running mine that way for 3 years with no troubles.
I just went to the auto parts store and bought bulk brake line 3/8 and bent as i needed. Running that is real easy (own a good flare tool and cutter) and to find the connectors you need and way cheaper than the braided line.
Kill Bill...et
Braided would look nice. Stainless would be the way to go, but it's a real bear to bend unless you have a nice tube bender. I did not so, the only stainless I went with was the return line right at the tank (behind the seat still). Works great if your not into it for looks. Just be sure you go with the EFI line...obviously.
Bad Idea on using brake line tubing for fuel lines. There's a reason why bulk fuel lines only come in 2 options, Aluminum or stainless.....RUST. Brake lines when using for brake systems are ok because it's a sealed system, for fuel though, rust can only lead to clogging. IMO, aluminum is the cheapest and easiest way to go, bends by hand and easy to flare. Stainless require a decent pipe bender that won't kink the tubing. Mentioned above is the high pressure hose. Stock fuel lines in vehicles use this in sections of the fuel lines, but i wouldn't trust a flexible hose from tank to motor due to how it can move around, and thus rub, on whatever it's nearby, and eventually rub through.
'72 Chevy Longbed 327 w/ 3 on the Floor-soon to be DD '71 GMC Longbed (originally bought project, now parts truck for '72) '94 Camaro Z28 cam/exhaust/gears '02 Chevy Impala-DD for now -Ryan, GM Master Technician |
#9 | |
get it! |
You can get S.S. fueline tube from Inline Tube, or try these guys:
stainlessFuelLines.htm
I initially went with stainless and I couldn't get it to flare good enough to seal, so I ended up using aluminum hard line with a few short sections of braided to connect up to the fuel rail, from the tank to the regulator/filter, and then to the hard line. You need to run something flexible between the hardline to the engine to allow for engine movement.
It would have been a lot easier to just run braided hose the whole way. Doing it the way I did requires a few extra fittings that also add up. |
Take a look at Cunifer fuel/brake lines from FedHill.
http://store.fedhillusa.com/ I plan on fabricating my own brake and fuel lines (for 6.0L LQ9/4L80E transplant) in my 67C20 |
The last 2 swaps I have done I used dorman hard plastic line. Its the hard plastic line like found on many newer vehicles. It is very easy to work with once you get the hang of putting the fittings on, and cheap. You can buy all the plastic quick connect type fittings, you just dip the end of the hose in boiling water and push the barbed fittings on. I was skeptical at first but the only way to get the fittings back off is to cut them off. Heres pretty much all the parts
http://www.dormanproducts.com/docume...uyersGuide.pdf |
#14 | |
#15 | |
as for there being 2 diff in/out sizes many of the pumps are that way, I am pretty sure the walbro can be had with the same in/out size. On my truck i just have a cheap inline for mid 80/90's ford trucks/vans. They are about $50 or so. In their factory configuration they had a low pressure in tank pump that fed the high pressure pump. My truck, and my buddies 69 camaro are just running the high pressure pumps and have done fine, his car has been on the road for a couple years. Another buddy is running an inline walbro 255, in a 69 camaro, it is not that loud mounted to the truck floor, so Below the cab mounted to the frame rail I don't think it would be that loud at all. Last edited by junkman; 04-12-2010 at 10:53 PM. |
#16 |
Hadn't seen that before. I'm considering it for my build now though!
#17 |
Thanks for all of your thoughts you have opened the doors for alot of options. One question though on the aluminum fuel line will it stand the fuel pressure?
#18 |
i have one more question. For those of you running inline fuel pumps which one do u recommend. I read alot of walbro pumps being noisy but of course i have read not heard so any info or recommendation would be great. thanks
#19 |
Kill Bill...et
I didn't go with the Walbro. It's been a while but I think I went with an Accel pump. Mounted underneath the drivers door on the frame. I've got a strip of rubber (about 1/6th inch) between the pump and the frame. A little hum, but not as bad as I've heard people complain about. Just enough to remind you it's still running.
#20 | |
hmm i figured u wouldnt want to mount that pump way up there. Anyways ive been looking at the bosch 044 and the walbro 255 but im still a lil confused on why they have a two sizes on the ends of the pump |
#21 |
Kill Bill...et
Oh yeah. I still have the tank behind the seat. That's why the pump is all the way up there. Guess I coulda mentioned that.
As far as the two different sizes, I imagine it has something to do with the gravity feed to the pump hence the larger 3/8th's inlet, but TPI roller type pumps normally have a 5/16th's outlet. I can assure you, you'll have no problems feeding your motor with that Walbro pump. You may have to tinker toy some fittings together to get it to match up with your fuel rail. |
#22 |
these are all great ideas im just getting ready to do my fuel system. subsribing.
#23 |
ok so im gonna run aluminum hard lines and 3/8 fuel injection hose where the pump/filter are and from the tank to hardline and hardline to fuel rail. My question is on these fuel pumps all of them are 3/8 to 5/16 outlet or 3/8 to 10mm either way going smaller on the outlet side so what do i need to do to fix that ordeal.
http://www.jegs.com/i/MSD+Ignition/121/2225/10002/-1 http://www.summitracing.com/parts/VPN-GSL392/ |
#24 |
Omg lol that's terrible alright I'll just go 5/16s from the outlet of the pump and switch back to 3/8 before I get to the fuel rail. I just heard on the walbro pumps they don't last long so alot of ppl run the Bosch 044 because of realiability and it's quiet
#25 |
![]() Join Date: Aug 2004
I have a Pierburg and you can bearly hear it running, it came with rubber jacket and it will easily feed my 4.8.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
