![]() Join Date: Jun 2017
Exhaust down pipes
DOES ANYONE KNOW WHERE I CAN FIND 2.5 IN DOWN PIPES FOR A BIG BLOCK I HAVEN'T FOUND ANY YET tHANKS
Re: Exhaust down pipes
I looked a long time for these when I did my truck. Ended up ordering a set from Waldrons Exhaust in Michigan. They have to make them, and there is a waiting period. You have to order the set for a 396 truck to get the 2 1/2" pipes. They also only had the pattern for a long wheel base truck, so I had to cut them off before the up and over at the swing arms and adapt them to another exhaust system I used for the rear which was 2 1/4". This was the only answer I found.
1968 SWB Step Side, Big Block, 4L80E , Running! |
I was assuming that you were going to run stock exhaust manifolds.
![]() Join Date: Feb 2010
Location: Falls City, Nebraska "100 Miles From Nowhere"
Found these on Amazon, not a bad price considering that they're Stainless Steel. https://www.amazon.com/Pypes-Exhaust...down+pipes+BBC I would just go to my local muffler shop and have them bend you up a pair. They can flare the ends and provide the three bolt flanges as well...
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" ![]() "Be American, Buy American" ![]() |
