Radiator
Are their any stock 4 core radiators that will fit in my 62 half ton's stock location? I dont mind doing any fabrication of mounts, just as long as the size fits. Thanks
60-66 Nut
Re: Radiator
Aside from an original style for the '60-'66 trucks, one from a '67-'69 Camaro or a '68-'72 Nova can work. There are a couple different sizes available, you'll want the shorter one for a small block. Although I don't know how easy it would be to get a 4 core one.
Since you're able to do a little fabricating, don't overlook the universal aluminum radiators from Summit. Several guys have been using them with good luck, and they're not too expensive. ChiefRocka did a write up when he installed his http://67-72chevytrucks.com/vboard/s...d.php?t=289262
Re: Radiator
Thanks Captainfab that helped out a lot.
Re: Radiator
I got mine from napa (4 core) and my truck runs real cool, ahd it for 6 years and no problems, fits right in, no fab needed.
Re: Radiator
Would you happen to recall the part #? Thanks
Re: Radiator
No, but if you search it on their online website it sure looks like the same one.
Resistance is Futile
Re: Radiator
I used the same radiator as Cheif and its worked well. Its a Summit piece. Its easy to install, affordable and keeps my truck cool idling in Phx 100+ degrees with no shroud. I use a mechanical fan, at the moment.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
Re: Radiator
Thanks protrash64 that sounds like the way to go, I was just a little cautios about another 2 core since mine lets the gruck run hot.
Ol' Blue Viking
Re: Radiator
Driving Paw-paws truck into the Sunset! |
Re: Radiator
I think the core size is bigger so it may be a two core but equalls the mass of a four core, the summit one is what I used, very little fab work and looks good too.
One day...
Re: Radiator
Ya id use the aluminum one from summit too bc of looks and hey its aluminum.. but fyi one will work for a 74 chevy pickup for a BB its wider and not as tall
Re: Radiator
Just a bit of info to help clear things up. Good Luck
The radiator people say............. Copper Brass versus Aluminum Example A copper brass 4 rows of 1/2" tubes and Example B aluminum 2 rows of 1" tubes. Seen in example A is a copper brass core cross section using 1/2" tubes. Much of the cooling efficiency is lost because of the limited amount of tube-to-fin contact. Seen in example B is an aluminum core cross section using 1" tubes. Since the aluminum tube is a minimum of 1" the efficiency of tube-to-fin contact is much greater. In fact a two row 1" tube radiator has 40% greater tube-to-fin contact over a 4 row copper brass radiator (this can be seen in the examples above by comparison of the measurement B). Therefore the cooling efficiency is vastly improved over that of a copper brass core. I couldn't copy the picture but here's the link. http://www.bsandbradiator.com/aluminum.html
1963' Chev Custom Cab 502, 67' 435hp 3X2 intake, 9" 4:30 Posi 1961 Impala SS 348/350 4-speed 3:70 Posi 1961 Bel-Air Bubble Top 283 Turboglide soon to have a 348 3X2 4-speed 1950 17' Fairliner twin cockpit barrel stern 312 Y block 1X1 intake Borg Warner 1:1 gear 1957 Fleetform 14' twin cockpit barrel stern 1969 BP-125 Merc 1949 Transitier 3-wheel forklift Crosley 4-Banger 98' FXD 2002 2500HD |
One day...
Re: Radiator
Cool good info
Re: Radiator
Dang! sounds like we have a rocket sicentist in the forum. LOL. great info 502, I really apreciate it.
#15 | |
One day...
Re: Radiator
![]() ![]() I thought the same thing! but he wrote it from the site, and its good info to! |
#16 |
Keepin it old school
Re: Radiator
I also used the summit aluminum radiator fits well and cools good. (SUM-380324) Thanks Chief..Was running hot before but not since installing it... I did have to take it to the welding shop that had a TIG. The lower radiator hose outlet angle needed to be changed. Just like Chiefs did.. Also the stock upper radiator mounting bracket was just shortended
(dont mind the messy engine and engine compartment that was before the engine rebuild ![]() ![]() ![]() Last edited by Bazooka; 11-02-2008 at 12:15 PM. |
