Old 03-08-2017, 10:22 PM   #1
jlipman
Leaky air bag set up
I'm finally at the point in breathing life back into my truck that sat for 10 years where the big stuff is done. Now I need to chase the leaks in my air bag set up. I used the kids bubbles mix to spray the lines but seeing the bags is not so easy. Has anyone tried putting push connect valves in line to isolate areas to narrow the area to search? I think they are leaking out if the fittings in the bags.
jlipman is offline   Reply With Quote
Old 03-09-2017, 12:24 AM   #2
tommys72
tommys72's Avatar
Re: Leaky air bag set up
I had a bagged S10 for quite a while. It sat for the better part of 2 years while i was in Japan and then a year again while deployed to Afghanistan. It was real leaky when i got back to driving it. If i was you, id replace all the air lines. Then see what it does. I ended up rebuilding all my valves too, never had a leak again up til me selling the truck. The valves are easy to rebuild
United States Marine Corps 2000-2011
Iraq and Afghanistan veteran
Just living life now and enjoying it and my wife, daughter and son
tommys72 is offline   Reply With Quote
Old 03-09-2017, 11:01 PM   #3
HO455
HO455's Avatar
Just my two cents worth. Adding components also adds potential leaks.
RIP Bob Parks.
Old 03-09-2017, 11:20 PM   #4
57larry
I got tired of fighting my air bag leaks. installed dropped spindles and springs
57larry is offline   Reply With Quote
Old 03-09-2017, 11:36 PM   #5
jlipman
I would only put the valves in to isolate the leaks then remove them. I'm going to give it a go. Then I can isolate the valves and the bags in an organized way. I'll let you know if goes.
Old 03-10-2017, 03:14 PM   #6
Coley
Coley's Avatar
Smile Re: Leaky air bag set up
I use 'push-in' fittings all the time in designing, building and troubleshooting industrial/automation pneumatic (air) systems.
If I want to isolate an area or a device or a line, I simply take the hose off the device and bend it back 180° and temporarily put a tie wrap on it.
Despite how this sounds, it works great, it's quick, it doesn't leak and the quality of hose that I use on my projects (SMC/FESTO) suffers no degradation from this....and again, its fast.
You just have to 'get good' on how to remove the hose from a push-in fitting...which requires you pushing the hose 'in', the pushing the fitting lip in...the pulling the hose back out again.
Here is a quick pic of one of my typical (partial) installations
My two bits.
Coley
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL
1966 Chevy 1/2 ton (Florida- Red/white)
1972 Chevy 1/2 ton (California- Blue/white)
2005 Chevy Silverado HD2500/Duramax
2000 Dodge Ram 1500
Coley is offline   Reply With Quote
