Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1960 - 1966 Chevrolet & GMC Pickups Message Board > 60-66 Suburbans
Old 03-21-2015, 11:54 AM   #1
GRIMACE 65
its been to long
So about 3 months after I got the Burban the motor blew and it was put in the garage and has been sitting for the last 3 years. I have finally got off my lazy ass and Started to work on her. So I ditched the old 283
And removed the heater box and im smoothing out the fire wall
I also finally got my motor back from the machinists and bought a bunch of stuff for it
GRIMACE 65 is offline   Reply With Quote
Old 03-23-2015, 06:27 AM   #2
MikeS.
MikeS.'s Avatar
Re: its been to long
What size is the new motor?
Past Master
Triluminar Lodge #117 GL of WVa
My 1963 4x4 Suburban build;
http://67-72chevytrucks.com/vboard/s...d.php?t=531274
My Gallery, now with pics of my 1966 C30 motorhome.
http://67-72chevytrucks.com/gallery/...&ppuser=103447
MikeS. is offline   Reply With Quote
Old 03-23-2015, 08:42 AM   #3
GRIMACE 65
Its a 350 4 bolt main bored 40 over:
Steel crank
H-beem rods
Srp pistons (10:1)
Mellings high volume high pressure oil pump
Clevite 77 race bearings
GM Bowtie phase 2 heads (ported and polished )
Crane 1.5 roller rockers
Comp Cams xs274s cam (mechanical )
Edelbrock RPM air gap intake (ported and gasket matched to heads )
Holley 750 carb
Full MSD ignition
Hopefully it will be around 450+ hp
Old 03-30-2015, 05:46 PM   #4
MikeS.
MikeS.'s Avatar
Steel crank
H-beem rods
Srp pistons (10:1)
Holley 750 carb
Full MSD ignition
Very nice, I need one of those for my 63.
Past Master
Old 04-26-2016, 12:54 AM   #5
GRIMACE 65
Heres a update I finished up the engine bay and got the suspension on.
I bought a new posi and gears with the 5 lug Moser Axels.
I also got my new trans! I decided to go with a 4L60E SS model from monster transmission instead of the 700r4.
I got some new wheels as well and got the rear suspension back in 4"hd springs with 2" blocks.
Hopefully I'll be able to get her running in the next month or so. I still have lots to go with plumbing the brakes , cooling lines, and fuel lines.
Old 03-23-2015, 11:52 AM   #6
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Nice work. What headers are those?
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 03-23-2015, 11:59 AM   #7
GRIMACE 65
They're Patriot clippster mid length
Old 03-23-2015, 01:15 PM   #8
Joe Pass
Joe Pass's Avatar
I can't wait to see this motor in there....
Joe Pass is offline   Reply With Quote
Old 03-23-2015, 01:55 PM   #9
GRIMACE 65
I cant either... I still need to get the trans (700r4)
Old 04-26-2016, 06:33 AM   #10
gostranger
65 suburban vortec 5.3 bagged
gostranger's Avatar
very cool nice work!!!!
gostranger is offline   Reply With Quote
Old 04-26-2016, 07:38 AM   #11
GRIMACE 65
Old 04-26-2016, 07:56 AM   #12
duallyjams
duallyjams's Avatar
You left that sitting in your garage, huh if I had known that I would have try to talk you out of it, glad to see your back on it.
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
