What did it weigh?
What was the approximate curb weight of a 1971 Chevrolet C-10 pick-up truck with: a 350 V-8, TH-350 automatic trans, 2WD, long bed, 6-lug wheels, leaf-spring rear suspension, A/C, etc.?
Re: What did it weigh?
Don't normally do these but it is an interesting change for me.
Remember weight changes can be very model specific. 72 C10 CE10927 Curb Weight and popular option changes. Front Rear Total 2280 1546 3826 --36 --11 ---- 350 V-8 Engine upgrade (LS9) --12 ---5 ---- Turbo-Hydramatic Trans. (TH350) --90 --10 ---- A/C (C60) --33 ---0 ---- P/S --21 ---3 ---- P/B --19 ---0 ---- Front Stabilizer Bar ---7 ---2 ---- Radio --10 ---6 ---- Cheyenne Trim ---0 --23 ---- Rear Leaf Springs (-27) -95 ---- Step Bumper 2481 1701 4182 options total change +356lb
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
#3 | |
Active Member
![]() Join Date: Jul 2007
I am curious about the radio weight though -7# in front and 2# in rear.
68 GMC 250/3 speed Saginaw p/b p/s 69 Chevy 350/350 currently in pieces still lookin for a cab 06 Trailblazer I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive... |
Simple. The radio weighs 9 pounds and is installed behind the front axle. The weight is dispersed between the front and rear, biased towards the front.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
I think he is referring to the fact that it is -7# (negative) on the front axle meaning the front end gets lighter. It looks like its probably a typo and it should be 7# on the front and 2 on the rear.
Will 1970 CST10 SWB LQ4/4L80E 2004 Silverado (sold) 2007.5 Dodge Ram 2500 |
Good information ... thanks. So, in short a typical '71-'72 weighs around 4,100 lbs.
Now I am curious to weigh my truck as I have installed a host of aluminum items including: cylinder heads, intake manifold, water pump, and radiator. |
Its not a typo. There are limitations with the WYSIWYG standard editor.
You can't just use spaces and get things to wrap properly. The only negative value is the step bumper unloading the front axle by -27lb.
