Old 05-01-2008, 08:19 AM   #1
Riveted1
Tasty Cakes!
Riveted1's Avatar
What is this?
Is this right? What did the PO do here?? Found this in my door and several hidden spots around the body...
I'm a little and a lot
Ground beef: A cow with no legs.
'66 Chevy SWB "Penny"
'67 Chevy Big Window SWB- aka "Pearl"
'72 Burb- "Betty" "It's not a hearse dammit"
'99 Chevy Ext. cab Silverado
Riveted1 is offline   Reply With Quote
Old 05-01-2008, 08:25 AM   #2
IvelDesigns
Commander Taco Bello
IvelDesigns's Avatar
Re: What is this?
has the truck been painted? it looks like the PO welded up a hole in the door.
IvelDesigns is offline   Reply With Quote
Old 05-01-2008, 08:53 AM   #3
chevychase
chevychase's Avatar
Re: What is this?
X2.... better than bondo!
Joe
chevychase is offline   Reply With Quote
Old 05-01-2008, 09:28 AM   #4
Shaffer4
Strange Cousin From The West..
Re: What is this?
I'll take a wild guess and say he removed the body trim and welded in the holes.
Shaffer4 is offline   Reply With Quote
Old 05-01-2008, 10:47 AM   #5
Riveted1
Tasty Cakes!
Riveted1's Avatar
Re: What is this?
Yeah, I know it's welded, but what are the lighter areas that look like "worms"? Sorry for my ignorance, but I'm new to welding/body work.
Old 05-01-2008, 10:59 AM   #6
72lb4x4
Re: What is this?
Whatever it is, it shouldn't drip that way. Hah!!!
72lb4x4 is offline   Reply With Quote
Old 05-01-2008, 12:46 PM   #7
Re: What is this?
Prolly drilled hole for bondo to grab better.
Old 05-01-2008, 01:03 PM   #8
braggwood
Re: What is this?
You could look inside my doors, fenders, cab and bed and see the same thing, I removed the trim and welded the holes. If it is a good job, you and I will be the "only" ones that know it too.
braggwood is offline   Reply With Quote
Old 05-01-2008, 02:09 PM   #9
70GMCer
70GMCer's Avatar
Re: What is this?
Is that maybe sound deadener material that melted when it heat hit it?
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 05-01-2008, 02:19 PM   #10
corn
Re: What is this?
those "worms" are body filler. not the best way to do it, but I wouldnt worry too much about it...
corn is offline   Reply With Quote
Old 05-01-2008, 05:05 PM   #11
matthufham
Re: What is this?
maybe a dent was there or even a hole + dent, so the little holes are from a slide hammer, and the big hole got welded shut and the small ones bondo'd over.
matthufham is offline   Reply With Quote
Old 05-01-2008, 05:19 PM   #12
1956cameo
1956cameo's Avatar
Re: What is this?
Those "worm" like protrusions are definately bondo. I have seen that a hundred times on the backside of sheet metal that was pulled out by holes and a slide hammer.
1956cameo is offline   Reply With Quote
Old 05-01-2008, 05:59 PM   #13
Riveted1
Tasty Cakes!
Riveted1's Avatar
Re: What is this?
Ok makes sense! The big hole was where the trim hole was (Shaffer4 guessed right!) and I just didn't know what the other stuff was. The "worms" are only in a few hidden places, so it kinda freaked me out
Old 05-02-2008, 08:11 AM   #14
wzuke
wzuke's Avatar
Re: What is this?
I agree that it looks like body filler. Coat the weld and "worms" with something waterproof - maybe epoxy or at least rustoleum paint. Body filler is like talc and absorbs moisture if left uncovered it will start to blister.
wzuke is offline   Reply With Quote
