02-27-2012, 02:58 AM | #1 |
dumb pinion shim question
sorry for the stupid question, but im putting diy4x's e-z blocks (the ones that bolt to the spring pack) for the front. do i put the pinion angle shims between the ez inch and the sping? or between the perch and the ez inch? basically all i want to know is should i put the shim above or below the ez inch? thanks.
02-27-2012, 10:40 AM | #2 |
Re: dumb pinion shim question
I would put it between the ez inch and the spring perch.
This way the center bolt will tighten up strait.
72 k/10 short wideside 72 k/5 Blazer 72 K/5 Blazer - obstacle course racer 72 custom/10 8' bed 70 K/5 Blazer 67 C-30 GMC Flat bed 86 GMC K2500 Plow Truck 85 GMC K3500 84 M1008 85 M1008 77 G30 Motor Home 72 Sears 12hp Tractor Glenmoore, Pennsylvania |
02-27-2012, 11:21 AM | #3 |
Yes on the perch BUTTT if they are aluminum throw them away and get STEEL ones. Especialy for the front. Alum will crack, wiggle out = loose spingpacks up front = scary ride/crash.
I had this happen, lucky for me it was the rear, turned my spingperches into rounded off bent arches but I didn't crash. .025c
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks |
02-27-2012, 06:51 PM | #4 |
There solid steel dont worry haha im not that stupid lol
Posted via Mobile Device |
