Old 10-23-2012, 02:31 PM   #1
slam59
Have any of you painted your shroud...
or any other plastic area or part under the hood? If so, did you use high heat engine paint or plastic paint? My mechanic friend said to use the high heat engine paint. I thought about black dupli color paint thats meant for plastic. Is it ok to use the engine paint on hard plastic like the shroud? I am taking off the metal part on top of the shroud to paint it black. The shroud cleaned up good, but there are parts that are darker and shinier than other areas so I thought about painting it. Are there plastic cleaners or things that might renew it back to black? Here is the shroud below. In excellent shape, solid, with no tears or rips or pieces missing. Original GM part that came off a 74 like mine.
1974 C10 swb 350
1977 3/4 ton Silverado 454
1999 2 door 2wd Tahoe
slam59 is offline   Reply With Quote
Old 10-23-2012, 03:30 PM   #2
riz
Re: Have any of you painted your shroud...
I'd use either high temp and fusion plastic paint.
RIZ
riz is offline   Reply With Quote
Old 10-23-2012, 04:52 PM   #3
carboncrew
carboncrew's Avatar
I would use black SEM Trim Paint. Works great.
carboncrew is offline   Reply With Quote
Old 10-24-2012, 08:16 AM   #4
dwatts1984
Ive painted quite a few plastic parts under the hood. Ive found the best combo is an adhesion promoter for plastics. A good high temp primer, and high temp paint. Adhesion promoter will allow whatever the primer and top coats are to bond to the surface. Therefore whatever your putting on after the adhesion promoter will stick pretty well.
Just be sure to clean the part extensively!!!!!!!!!! Any oils grease or even fingerprints when exposed to heat will cause the paint to bubble rapidly.
dwatts1984 is offline   Reply With Quote
Old 10-24-2012, 09:58 AM   #5
slam59
DWatts, I've read a few things online that say the same steps as you say. Also heard some will apply a clear coat afterwards to make cleaning the painted areas easier once its in use. would'nt the clear coat peel off easily or no?
1974 C10 swb 350
Old 10-24-2012, 04:18 PM   #6
wilkin250r
wilkin250r's Avatar
Is high-temp paint really necessary? The shroud is plastic after all, I would think a regular (non high-temp) paint would survive any temperature extremes the plastic can.
I know a little about cars, but if you have a question about electricity or sport quads, I'm your man!!!
wilkin250r is offline   Reply With Quote
Old 10-24-2012, 05:54 PM   #7
Redcap
Rough it up (or use adhesion promoter) and paint it. High-temp paint not required.
Redcap is offline   Reply With Quote
